I was following that gutted stock muffler thread on M3forum but forgot about it, not realizing until the forum died. Wish I could read it still. What was the general consensus with how it turned out for people?
Gutted muffler thread?
One of the best video of debaffled section 3:
https://www.youtube.com/watch?v=YfbZ...ature=youtu.be
and a few posts about it:
https://forums.m3cutters.co.uk/threa...baffle.199357/
The first post with 2 pictures is the actual unit that I've bought from a member on M3forum; debaffled & straight piped chamber 3 and 4 I believe.
Tone wise, it sounds extremely similar to stock but when you romp on it, it does bark at a volume level that is significantly higher than stock; Overall no drone at cruising.
Pretty pretty goodDD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
Originally posted by Sprp85 View PostOne of the best video of debaffled section 3:
BTW any idea on the weight difference between stock vs gutted?
Originally posted by shibui View PostBTW any idea on the weight difference between stock vs gutted?2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - Kassel MAP - SSV1 - HJS - PCS Tune - Beisan - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
I couldn't feel a difference after gutting.
Thanks man. I see you're located in the Bay (where my car is although i'm working abroad at the moment). Did you get a shop in the Bay to do the exhaust work? If so could you recommend it to me? From your video your setup sounds great.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - Kassel MAP - SSV1 - HJS - PCS Tune - Beisan - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
