Center the steering wheel then lock it with the key out of the ignition. Then just make sure the stick out of the rack gear from the steering housing body is the same on both sides when you attach it to the steering column. You will then attach the tie rods after the rack is attached to the subframe.
If you are changing from CHF to ATF, I would get a new reservoir. It has an integrated filter and it makes sense to replace it.
Correct part number: 32416851217
Also Banjo bolts need to be replaced?
