The spark plugs come pre-gapped but is the actual gap specified in any BMW documentation?
Spark plug gap?
If you buy correct plugs for S54, they come properly pre-gapped to .032 inches.
BKR6EQUP (NGK-3199)
BKR6EQUP (NGK-3199) a.k.a. Laser Platinum - This is the stock plug for E46s. It has has four ground electrodes, two primary, two secondary. Primary is gapped differently from secondary and why you shouldn't regap. The plug randomly fires to these gaps thereby reducing carbon build up or fouling. Again, this plug is pregapped and should not be adjusted. Yes, you will notice each of the four electrodes has a slightly different gap, this is by design.Last edited by TexaZ3; 01-14-2024, 04:36 AM.BMW / E46M Interior & Trim Restoration.
The S54 spark plug is DCPR8EKP and they are pre-gapped.Originally posted by TexaZ3 View PostIf you buy correct plugs for S54, they come properly pre-gapped to .032 inches.
BKR6EQUP (NGK-3199)
BKR6EQUP (NGK-3199) a.k.a. Laser Platinum - This is the stock plug for E46s. It has has four ground electrodes, two primary, two secondary. Primary is gapped differently from secondary and why you shouldn't regap. The plug randomly fires to these gaps thereby reducing carbon build up or fouling. Again, this plug is pregapped and should not be adjusted. Yes, you will notice each of the four electrodes has a slightly different gap, this is by design.Last edited by Slideways; 01-14-2024, 11:58 AM.
.032 like Texas said.
Original plugs were double electrode platinum pre gapped to .032. Ngk iirc. Not Bosch.DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
Originally posted by Slideways View PostThe S54 spark plug is DCPR8EK and they are pre-gapped.
Four grounds, are for non-M E46, IIRC.So which is it boys? Sometimes I really question the credibility of the information on this site.Originally posted by TexaZ3 View PostIf you buy correct plugs for S54, they come properly pre-gapped to .032 inches.
BKR6EQUP (NGK-3199)
He has much more than 5 lolOriginally posted by Slideways View Post
NGK - DCPR8EKP
Tex has like 5 cars and one of his other cars might use the ones he quoted.
The ones he quoted are S62 plugs.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - SSV1 - HJS - Mullet Tune - MK60 Swap - E86 Front Triangulation - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
- Likes 3
Yup, I honestly thought I was posting reply on M5Board! Sorry about that, was early morning, not enough coffee.Originally posted by Slideways View Post
NGK - DCPR8EKP
DCPR8EKP is correct for S54, not the other one I posted in the first post. That was for S62.
- Likes 4
