CSL Rev Matching is for me to dangerous.. i do this now automatically with ecuworx for 20 pounds
DIY: Flashing your SMG module with CSL Software + CSL Rev Matching and Torque Maps
Originally posted by E46m3zcp View PostIs this different than TTFS or Build Journal tunes?
I have compared a few of these small tuner engine calibrations to the factory CSL. In certain cases, the changes made to the maps were either minimal or very questionable.
Great. At step 3 right after setting up WinKFP, when entering the Comfort mode and the "ZUSB" I get different options than in the screenshot for "integration". Any idea what this is? According to Google Translate "Unverbaut" from the original screenshot means unobstructed, if that matters :-)
If I move on to the next step, after clicking "done" the contents of the main screen are identical to the screenshot in the original post.
EDIT: After closing and re-opening WinKFP, I get identical screens as in the original post.Last edited by E46m3zcp; 08-27-2024, 08:24 PM.
I followed the TCU flash steps with WinKFP and as some people described it took about 30 seconds and I did not get to the second faster run. Do we have any info on what might be the cause for this? I feel like something got missed in the process.
EDIT: Well, it worked - the car defaults to auto mode and the shifts are as they should be.Last edited by E46m3zcp; 09-30-2024, 07:33 PM.
What does the "SMG inertia update" do?3.91 | CMP Subframe & RTAB Bushings | SMG (Relocated & Rebuilt) | ESS Gen 3 Supercharger | Redish | Beisan | GC Coilovers & ARCAs | Imola Interior | RE Rasp | RE Diablo | Storm Motorwerks Paddles | Will ZCPM3 Shift Knob | Apex ARC-8 19x9, 19x9.5 | Sony XAV-AX5000 | BAVSOUND | CSL & 255 SMG Upgrades | Tiag | Vert w/Hardtop
This option increases the clamping force of the clutch reducing SMG ‘clutch slur’. It is recommended when using the CSL SMG Shifting and Rev Matching option.
Has anyone experience the following?
I have a 2005 ZCP SMG and have converted drivetrain to CSL (airbox, oem snorkel, MAP sensor, CSL tune, Martyn tool, etc).
Now when driving in S4, the upshifts are OK, downshift blips are great (when shifting +3500). Blip matches revs and there is no engine breaking (actually blip slightly over revs).
In S5, the upshifts are great (a little clunky, but that's expected), but the downshifts unsettle the car. When I blip (again +3500), the rev match is horrible. It's like the car needs to blip 1000rpms to fully match, and it blips 600rps and engine brakes the remaining 400rpms... the car becomes totally unsettled and quite dangerous.
I would imagine this isn't supposed to happen. Can any-one take a look at my SMG tune? I got it back in 2010, so i don't remember who did it but I can't imagine BMW OK'ing something like this.
If this IS the correct tune from BMW, is there anyway someone can adjust S5 and S6 rev matching?
What gear does your car start in? If you have the CSL tune it will start in A3 every time. Regardless I would flash using these instructions.3.91 | CMP Subframe & RTAB Bushings | SMG (Relocated & Rebuilt) | ESS Gen 3 Supercharger | Redish | Beisan | GC Coilovers & ARCAs | Imola Interior | RE Rasp | RE Diablo | Storm Motorwerks Paddles | Will ZCPM3 Shift Knob | Apex ARC-8 19x9, 19x9.5 | Sony XAV-AX5000 | BAVSOUND | CSL & 255 SMG Upgrades | Tiag | Vert w/Hardtop
