CSL Rev Matching is for me to dangerous.. i do this now automatically with ecuworx for 20 pounds
DIY: Flashing your SMG module with CSL Software + CSL Rev Matching and Torque Maps
I would assume that they are not different. It can easily be checked by looking at the calibration maps and comparing them to the factory CSL. I would 100% stick to the factory CSL calibration for the SMG system.Originally posted by E46m3zcp View PostIs this different than TTFS or Build Journal tunes?
I have compared a few of these small tuner engine calibrations to the factory CSL. In certain cases, the changes made to the maps were either minimal or very questionable.
Great. At step 3 right after setting up WinKFP, when entering the Comfort mode and the "ZUSB" I get different options than in the screenshot for "integration". Any idea what this is? According to Google Translate "Unverbaut" from the original screenshot means unobstructed, if that matters :-)
If I move on to the next step, after clicking "done" the contents of the main screen are identical to the screenshot in the original post.
EDIT: After closing and re-opening WinKFP, I get identical screens as in the original post.Last edited by E46m3zcp; 08-27-2024, 07:24 PM.
I followed the TCU flash steps with WinKFP and as some people described it took about 30 seconds and I did not get to the second faster run. Do we have any info on what might be the cause for this? I feel like something got missed in the process.
EDIT: Well, it worked - the car defaults to auto mode and the shifts are as they should be.Last edited by E46m3zcp; 09-30-2024, 06:33 PM.
This option increases the clamping force of the clutch reducing SMG ‘clutch slur’. It is recommended when using the CSL SMG Shifting and Rev Matching option.Originally posted by ac427 View Post
What does the "SMG inertia update" do?2003 | 3.91 | CMP Subframe & RTAB Bushings | SMG (Relocated & Rebuilt) | ESS Gen 3 Supercharger | Redish | Beisan | GC Coilovers & ARCAs | Imola Interior | RE Rasp | RE Diablo | Storm Motorwerks Paddles | Will ZCPM3 Shift Knob | Apex ARC-8 19x9, 19x9.5 | Sony XAV-AX5000 | BAVSOUND | CSL & 255 SMG Upgrades | Tiag | Vert w/Hardtop
Thank you.Originally posted by oceansize View Post
Has anyone experience the following?
I have a 2005 ZCP SMG and have converted drivetrain to CSL (airbox, oem snorkel, MAP sensor, CSL tune, Martyn tool, etc).
Now when driving in S4, the upshifts are OK, downshift blips are great (when shifting +3500). Blip matches revs and there is no engine breaking (actually blip slightly over revs).
In S5, the upshifts are great (a little clunky, but that's expected), but the downshifts unsettle the car. When I blip (again +3500), the rev match is horrible. It's like the car needs to blip 1000rpms to fully match, and it blips 600rps and engine brakes the remaining 400rpms... the car becomes totally unsettled and quite dangerous.
I would imagine this isn't supposed to happen. Can any-one take a look at my SMG tune? I got it back in 2010, so i don't remember who did it but I can't imagine BMW OK'ing something like this.
If this IS the correct tune from BMW, is there anyway someone can adjust S5 and S6 rev matching?
I don't experience what you do.Originally posted by x Spades x View PostHas anyone experience the following?
What gear does your car start in? If you have the CSL tune it will start in A3 every time. Regardless I would flash using these instructions.2003 | 3.91 | CMP Subframe & RTAB Bushings | SMG (Relocated & Rebuilt) | ESS Gen 3 Supercharger | Redish | Beisan | GC Coilovers & ARCAs | Imola Interior | RE Rasp | RE Diablo | Storm Motorwerks Paddles | Will ZCPM3 Shift Knob | Apex ARC-8 19x9, 19x9.5 | Sony XAV-AX5000 | BAVSOUND | CSL & 255 SMG Upgrades | Tiag | Vert w/Hardtop
Hi all, would appreciate some guidance - after several months of prep and planning, i am finally ready to flash the ECU and SMG module.
Everything has been smooth sailing for the most part, although hit a wall a moment ago in WinKFP (Version 5.3.1)
Everything looked perfect (attached screenshot showing so) right up until i hit Program, when i got the following error (also attached)
Any ideas? The only deviation I took from Martyn's instructions was that i sourced different E46 Daten files (from NCSExpert, V73 2024/10 Version) - but beyond that, followed all steps to a T.
By my account there were no issues with preparing WinKFP prior to attempting programming, all files and folders were copied/pasted in their respective places and everything looked ok.
What did i do wrong?
EDIT: port was set to COM3 in windows, changed to COM1 and resolved. First impression: WOWLast edited by sd561; 06-28-2025, 08:13 AM.
