The one I'm talking about is the one on the passenger side of the engine, that uses the 32mm socket to get off.
Engine noise
There is not much info on the thread pitch for the tensioner. You'll need a thread pitch gauge to check the size before ordering a tap - https://www.acehardware.com/departme...E&gclsrc=aw.dsOriginally posted by M3powerzz View PostThe one I'm talking about is the one on the passenger side of the engine, that uses the 32mm socket to get off.
I believe the tap is 22mm and 1.5mm pitch.Originally posted by M3powerzz View PostThe one I'm talking about is the one on the passenger side of the engine, that uses the 32mm socket to get off.
You MUST be very careful, slow , straight when insert and thread the tap into the hole. Your last chance.Last edited by sapote; 03-13-2024, 05:37 PM.
This is shorter than a normal tap, for a tight space:
https://www.amazon.com/Lisle-12180-Sensor-Thread-Chaser/dp/B0942TXHYK/ref=asc_df_B0942TXHYK/?tag=hyprod-20&linkCode=df0&hvadid=532826541792&hvpos=&hvnetw = g&hvrand=12691331187342093534&hvpone=&hvptwo=&hv qm t=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9031176&h v targid=pla-1375770061346&psc=1&mcid=8a5aaa68c49935a4b62c98250 c7f21e8&gclid=Cj0KCQjwncWvBhD_ARIsAEb2HW-CrG2P2donKq9AGvV4OoY1EJt1YJ0HLZanRgIflcZJIdlVkCLjw ckaAl75EALw_wcB
But, its pilot end doesn't look good to me as compared to a tap, so measure the tap length and if you can fit it in there, then I think the tap pilot can help to start the threads easier.
I'd try taking things back apart and running the tap through from the inside of the head. Threads are (presumably) still good there, which will give you a guide so you don't mess them up further. Just don't drop things into the oil pan...2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - SSV1 - HJS - Mullet Tune - MK60 Swap - E86 Front Triangulation - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
Great idea. Lower the chain down, remove the top R guide then push the lower guide away, then this should gives enough space to thread the tap from inside.Originally posted by heinzboehmer View PostI'd try taking things back apart and running the tap through from the inside of the head. Threads are (presumably) still good there, which will give you a guide so you don't mess them up further. Just don't drop things into the oil pan...
What does the head look like?2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - SSV1 - HJS - Mullet Tune - MK60 Swap - E86 Front Triangulation - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
