Started up the car this morning, heard something broke in the engine. Engine started making a scraping noise. I shut the car off right away. I took off the valve cover to find this , also the timing chain guide is broken, and the sprocket some of the edges is sheered off. Now I gotta figure out how to fix this. Or if anyone knows a good shop in the NYC area, I could take it too.
Engine noise
Didn't you rebuild the VANOS recently? - https://nam3forum.com/forums/forum/m...738-vanos-time
I see the stock oil pump disc. A redrilled pump disc is a must along with a new upper chain guide during a rebuild. You'll need another valve cover, possibly exhaust sprocket or exhaust hub, and complete VANOS unit as one of the oil pump pistons has damaged that VANOS unit. Are the two tabs on the exhaust hub still intact?Last edited by Slideways; 03-04-2024, 09:52 AM.
It seems the pump disk roller bearing seized up and self destroyed, then pushed the circlip one end off the groove, and all of the rollers (or pins) from the bearing fell down the oil pan (I would also check if any jumped in the cams/valves area). Some of the components fell on the moving chain and jammed on the sprocket. Hope the chain didn't jump over the sprocket to cause out of timing and bent valves.Originally posted by M3powerzz View PostStarted up the car this morning, heard something broke in the engine. Engine started making a scraping noise. I shut the car off right away. I took off the valve cover to find this , also the timing chain guide is broken, and the sprocket some of the edges is sheered off.
I only see one piston/spring of the pump, and where are the remain 3 pistons/spring?
with the pump pistons out of the disk, this means the pump disk is destroyed as the holes are enlarged.
Cross threaded - how far did you thread it in? If not too far in then use a thread tap tool to chase/clean the threads. I always tighten it by fingers a few turns before using a wrench.Originally posted by M3powerzz View PostWell today I went and changed the upper chain guide, while putting back the timing chain tensioner, I crossed threaded the hole, what would be a good fix for this? It's a really tight spot.
Did you find all parts debris in the oil pan and in the head?
Ah, misread that.Originally posted by sapote View Post
I believe he was talking about the big bolt/cap chain tensioner above the AC compressor.
A friend of mine had to do the chain tensioner thread repair on his S54. Dan, in the Pacific section, ordered the tools and did the repair, but he no longer works on cars. I'm guessing OP can get one of those thread gauges and order a tap or chaser to fix the threads.
