BBS LM "Tuner" Fitment Help - 19x8.5et18 (Front) and 19x11et25 (Rear)
    Originally posted by marksae View Post
    I'm running 19x8.5+17 fronts with 19x10+25 rears (not reverse mounted). Tires are 245/35/19 and 275/30/19.
    I am running -3.8 degrees of camber in front. I do have some slight rubbing, but that's a small price to pay for vanity!
    Looks great! Are you rubbing spacers in the front?
      No spacers front or back
      2004 Alpine White / Cinnamon E46 M3 6MT
      1993 Brilliant Black FD Rx7
      IG: @gearheadtwins
        Do not run 255/285. Don't get 11" wheels.
          Isn't the Tuner Fitment as follow? If so, go with 265/35 and 295/30...cut/shave/roll the rear inner fender liners.
          Front: Size: 19 x 9.5" et20 or 19x10" et25
          Rear: Size: 19 x 11 et25
            11" is total overkill on this platform. These wheels are already anchors... why go even heavier?
              Thanks for all the advice guys! I already purchased the wheels that gt4 posted awhile back. Once it gets in later this week, I’ll let everyone know how the fitment is! Excited!
              Hopefully the tires don’t rub!
              Wheels: fronts 9x19 ET27 LM403, rears 10x19 ET25 LM212
              Tires: Yokohama Advan Apex 255/35/19 front and 285/30/19 rear​
                Those should fit nicely, tbh I would go to like a 235/265 tire split and have the slightest bit of tasteful stretch.
                  Thanks for the vote of confidence. I hope the tires don’t rub! It shouldn’t though as all my fenders are rolled and shaved. Regardless, once these tires wear out, I’ll go with a slightly smaller size. Either with what you mentioned or 245/275.
                  on a another note, what do you guys think apex arc8s 18x9et30 with pretty much brand new tires would go on the used market? Haha no idea what I should list them at
                    I have the BBS LM tuner fitment wheels on my car. I mounted Continental DW 275/30/19 rear and 245/35/19 front. All is well here.
                      Any photos?
                        Wheels came and look amazing!! Fits perfect and no rubbing from the 255/35/19 front tires and 285/30/19 rear tires. Yoko Advan apex tires. Note that my car has the front fenders completely rolled and the rear is completely shaved. Lowered on Bilstein PSS10 coilovers.
                        Thanks for all the comments guys! Thanks Gt4 for the link and comment that these wheel sizes would fit well! Haha you should get a referral commission from the Seller for the sale =P
                          I thought that the LM turner setup was a 19x9.5 et32 for the front and 19x11 et25 rear. The LM 19x8.5's were paired to the 19x10's.
                            Pay attention to overall diameter of your tires. The Firehawks I'm running are both 25.8", and I'm running 245/35/19 and 285/30/19.
                            19x8.5 +35 front
                            19x10 +20 rear
                            2004 Dinan S3-R M3
                            2023 X3M Competition
                              I'm planning on running this BBS LM setup with no spacers, lowered on KW V3s, using BBS provided hub centering kit, unmolested OEM fenders:
                              19x8.5 +18 (LM431)
                              19x10 +25 (LM272)
                              Michelin PS4S
                              245/35/19
                              275/30/19​
                              I was going to go with +32 front, but this siq E46 M3 is running the LM431 specs with no rubbing whatsoever sans spacers. Can anyone else running the exact same setup verify all is good in no rub land? TIA!
                              P.S. Per IND, standard fitment is 19x8.5 et32mm / 19x10 et25mm and tuner fitment is 19x10 et25mm​ / 19x11 et25mm
                                You should wait for a set of F - 19' x 8.5 et 32 R - 19' x 10 et 25 to pop up for sale. ​
                                Any reason for going ET32s up front v ET18s on 19x8.5s?
