I run a stock bar with no rear bar. I am at 52/48 weight distribution, no rear bar helps with putting the power down. With a ZF 4 clutch LSD the rear end is far more controllable. I do want to put in a Hotchkis bar but that would be for weight savings.
I use the Bimmerworld end links. I found the BW hardware to be problematic...possibly a user issue. I've since installed some ends from McMaster Carr which have been trouble free and are much cheaper.
