As some of you know, I do the Apple CarPlay / Android Auto conversion on the original navigation systems.
I have had to pull out a lot of 5 meter extension cables from cars, where customer decided to go back to OEM, as they weren’t happy with the aftermarket.
Over the years I always read mixed reviews of the aftermarket headunits.
I decided to dig a little deeper and see what’s going on.
Since I had these 5m extension cables, I hooked them up to my test bench and started doing some tests with an aftermarket headunit.
Here is the results.
For cars which came with single din headunits, the connection is direct, so the reviews have always been generally positive.
Power cables being poor is bad enough, but also 5m of really bad speaker cables, makes it even worse.
I hope that clears things up and helps anyone.
