As the title states I am looking to remove to remove the pretensioners from my m3 and run rear buckles with some modifications like the S2K community runs with a fixed length rear buckle so the belt no longer has to go over the side bolster on my recaro pole position. Since this is an FIA racing seat and not a street bucket you can’t run the pretensioner properly through the pass through on the side like many of you know. This is sketch in an accident because you could in theory submarine.
Running a rear buckle will get the belt at a proper angle and of the two situations at least this will be holding you in the seat properly so when you fly forward the upper tensioner on the b pillar will still lock the entire seatbelt from letting you fly forward. Currently with the buckle going OVER the seat the buckle pretensioner is kinda worthless.
Now the dangerous way everyone runs these on the street because the seat is truly designed for harnesses only:
Now I want to get rid of the pretensioner buckle entirely and I know how to code everything out BUT I’m fairly certain that will just get rid of the faults for the missing hardware. What I’m not sure is whether it will truly disable the SRS system in an accident by missing the pretensioner buckle?
It appears there is a seat belt sensor in the buckle that tells the SRS system when a person is sitting in the car and buckled in so when there is an accident the airbags do indeed go off. If I remove the pretensioner that obviously would no longer be present.
I haven’t dug into the logic just yet but being a safety thing I’d like more assurance the front airbags will still go off in a front impact if I can tell the airbag system to ignore the presence of the pretensioner being a requirement? I’m not sure that’s possible but will be taking a look tonight.
Worst case I guess I could keep the pretensioner buckle hard mounted with a buckle permanently connected then run the rear buckle mounted but that’s ugly.
Curious if anyone has done this properly?
