Originally posted by old///MFanatic
IND | Rogue Engineering E46 M3 Aluminum Lifting Block Set
Is the rear jackpoint issue primarily when you try to jack the car up from one of them (meaning ~half the car's weight is on it)? I almost always jack from the rear subframe so both rears come up off the ground equally then use the factory rear jackpoints for my jack stands (so only a ~quarter of the car's weight is on each point).
I never lift the car by the jack blocks. Rear subframe and front "hockey puck" on the reinforcement plate.DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
Originally posted by tnord View Postdo you drive up boards or ramps to get enough height for a jack to get to the hockey puck? what's the difference between lifting the car by the jack blocks and resting the car on the jack blocks+jack stands?
Originally posted by LeeForst View PostI thought it was ok to quickly lift from one rear point in a pinch for a flat
The BMW accessory “Emergency Spacesaver Spare & Jack” kit come with similar jack and same use instructions.
Last edited by old///MFanatic; 06-16-2024, 08:24 AM.6MT SLICKTOP - OE CSL Wheels - OE CSL Brakes - CSL Rack - CSL Trunk - CSL Diffuser - AA Tune - AA Pulleys- AS 40% SSK - 4.10 Motorsport Diff - Bilstein PSS9s - H&R Swaybars - CSL Lip - Gruppe M CF Intake - Supersprint - M Track Mode
Originally posted by tnord View Posteven if you're using ramps, in the end you're still setting the car down on the pucks, so what would be so bad about lifting the car from the same spot?E46 ///M3 • 12/2002 • phönix-gelb • 6MT
Originally posted by bmwfnatic View PostThe rear jacking points in the E46 Coupe cannot support the weight of the car when lifted with a jack, the entire metal structure fails and tips inwards. It’s a design flaw, convertibles and sedans in my experience are not affected by this.
And BMW never posted a TSB about this afaik, and jacking flaw knowledge would be a severe safety issue. If it were a rust issue that’s another story. But a major design flaw at jacking points would need a safety bulletin no?6MT SLICKTOP - OE CSL Wheels - OE CSL Brakes - CSL Rack - CSL Trunk - CSL Diffuser - AA Tune - AA Pulleys- AS 40% SSK - 4.10 Motorsport Diff - Bilstein PSS9s - H&R Swaybars - CSL Lip - Gruppe M CF Intake - Supersprint - M Track Mode
Originally posted by old///MFanatic View PostI have never seen this design change. Do you happen to have info/documentation of this being a flawed different design between Coupes and Sedans/Convertibles? The only thing ever seen was it getting rusted out on some extreme cases. And the rears tend to be more prone to extreme rust.
