Starting a new thread related to a nearby clutch thread. I have been told that you can either buy a rear main seal assembly or a tool in order to install it to the correct depth. I cannot find the assembly for sale, is it still available? If not, the tool is for sale for $120. Does anyone have the tool available to lend, I’m willing to pay shipping. Thanks.
Rear main seal DIY
Youtube DIYs and more
I don't like these 'new style' seals that BMW has switched to, also retroactively for older cars it seems.
Over time the front and rear main seals create a low spot on the crankshaft, you can feel this spot with your finger, it's quite pronounced.
If you install one of those new style tensionless seals, and your low spot it quite large, they will never seal, they leak.
I prefer to stick to the 'old style' seals with a spring inside them, they provide more tension and are more forgiving if the crank surface they are riding on isn't absolutely brand new.
A generic 110x90x12mm seal with the right properties and a spring is suprisingly easy to source.E46 ///M3 • 12/2002 • phönix-gelb • 6MT
Originally posted by bmwfnatic View PostI don't like these 'new style' seals that BMW has switched to, also retroactively for older cars it seems.
The chart below shows the best rubber seal (VITON or FKM on the chart) only can handle up to 7000 rpm for out cars, and I don't think those rubber seals with the spring on the lip are even VITON.
I assume the crank seal is 3.5" or 90mm diameter (guessing from visual memory), then the circumference = 2R PI = 283mm
At 8000 rpm the surface speed is 283mm * 8000/60 = 38m/s which is more than 35m/s that can handle by VITON seal.
PTFE seal has the lowest friction so I'm surprised to hear that it caused the deep groove. Maybe dust/dirt collected at the seal lip did the wear on the shaft, not the seal.
https://advanced-emc.com/four-most-popular-rotary-shaft-seals-material-options-and-how-they-compare/Evolution of Seal Materials The evolution of seal materials evolved as seals faced more rugged demands. Early needs could be met using packed hemp or leather, but as the demands became more and more rigorous new materials were sought. This led to the introduction of natural rubber seals, which evolved into synthetic elastomers, and finally […]Last edited by sapote; 05-16-2024, 04:24 PM.
I believe only PTFE "new style" seal should be used on the S54 engine.
The PN# for the M/S5x kit is different than the pn# for the S54 kit. Looking at the parts the bolts are shorter for the S54. There is no listed part number for the housing so we don't know just looking at the diagram if it is different. BUT if the housing is "thinner" the bolts would be shorter.
So YMMV but the M/S5x kit may not wok on an S54. I'll see if I can measure some today.'09 HP2S, '12 R12GSA, '00 Black 323iT, '02 Alpine 325iT (Track Wagon), '02 Alpine 330iT
Email to [email protected]
Originally posted by Maxhouse97 View PostPart still not here from BMW parts factory (haven’t dealt with them before) and I made good progress last night, almost have the trans off. If I got into a pinch, could I install the seal I have without the factory tool? I saw guys on youtube using a block of wood…
'02 M3 6MT - Carbon Black/Dove Grey
'08 X5 6AT - Platinum Bronze/Nevada Beige
'01 325i 5AT - Orient Blue/Hell Beige (Sold)
'06 325i 6AT - Arctic Metallic/Black (Sold)
Instagram: @kylen.m3
Could we get some info on your processes of the removal of the box? i gotta pull mine to replace the input shaft seal
So far i found these steps for SMG in ISTA
Necessary preliminary tasks: - Disconnect battery, battery positive lead from battery terminal.
- Remove intake air manifold.
- Remove heater bulkhead.
- Remove fan with fan impeller.
- Remove engine splash guard.
- Remove reinforcement plate..
- Remove exhaust catalytic converter and intermediate pipes.
Depressurize hydraulic system
Remove heat shield Disconnect plug for transmission oil temperature sensor (1) and transmission speed sensor (2). Disconnect plug for reversing light switch (1). Unclip hydraulic lines at holders Release nuts and remove clutch slave cylinder (3).
Pressure pipe remains connected.
Slowly relieve tension on clutch slave cylinder (3) when removing otherwise air will be drawn in through sealing sleeve.Remove propeller shaftRelease screws and remove cross-member (1).
Lower transmission until cylinder head touches firewall.
Support engine at front.Lever out retaining ring (1) with a screwdriver. Drive out retaining pin (1) on selector rod linkage with special tool Release screws on actuator Unfasten screws and Pull out transmission as far as possible towards rear, turn approx. 10° in counterclockwise direction and remove.
Originally posted by BL92 View PostRemove propeller shaftLower transmission until cylinder head touches firewall.
remove starter too.
i think the engine rests on the subframe before the head touches the firewall.
yes, use floor jack to push the engine front up when removing the transmission, else it will fight you and then tip over when tranny if off.
