took forever to start this rebuilt, but didn't end up well as expected.
background:
car drops out gear fast, after a while, pop back to the gear where it left. not holding up pressure was my guess.
so what i did:
- took out smg pump, took it apart
- fit MLR orings for 4 sensors(x 12), gear's butterfly like o-rings x 2, and 2 or so small o-rings from the package
- fit MLR refurbished accumulator
- fit MLR new motor
- fit new smg plastic feedline from reservoir to pump
after put back:
- found leak at where the reservoir line to the pump, red collar area
- too tired to take everything apart, so i fiddled it with new o-ring + ziptie it done, seems to be not leaking. however, the line didn't sit all the way in (hence i ziptie it down first)
bleeding:
- tried to bleed it with ISTA, got stuck to step 3 i guess...weird noise
- error: 57 pump on time, and P1717
it primes long to stop.
what are my options now? if i take it apart again, where should i check? sigh
i activate one of the menu under ISTA to see the accumulator pressure, it shows 0.
background:
so what i did:
- fit MLR new motor
after put back:
bleeding:
