Black tag steering rack
    Has anyone on here tried a black tag steering rack from LPSR?
    WE ALSO SELL LHD VERSION click here (https://www.steeringlpsr.com/product-page/black-label-black-tag-lhd) A BRAND NEW BMW E46 RHD BLACK TAG 2.5 TURNS LOCK TO LOCK - PLEASE READ CAREFULLY! (1) Why so much effort for a quicker rack? - As you probably know, we have been dealing with steering conversion parts for BMW E30, E36 and E46 every day for many years now. Our new and remanufactured goods are shipped all around the world on a daily basis. We talk to our customers, we sort their steering issues, we also advise whenever we can, to get the steering feel optimised as best as possible. Every customer's situation is assessed individually and we are trying to find a solution to simply make everyone happy. That is why we KNEW THAT there is a high demand for a super quick, very responsive steering rack. SO.. HERE WE GO!    (2) What exactly is our BLACK TAG 2.5 TURNS SUPER QUICK RACK? -As you surely know there are plenty of myths regarding the number of turns, what rack fits where and what mods need to be done to get it all to work in your car. As we've stripped, assessed and built 1000s of E30s, E36s, E46s, Z3s racks, we feel more than comfortable to share our knowledge and debunk fake infos you can mostly read online. -Have you ever heard that the E46 ZHP yellow tag is the best rack? Or is the E46 CSL blue label even better? Purple tag? Quick Z3 rack? Linear and progressive? (there are no progressive racks in E30 E36 E46 and Z3 family - even if the rack splines are WORN and your Uni Joint has a play - it still does not make the rack progressive). Anyway, guess what? - our BLACK TAG beats all of them! SOME TECHNICAL INFO NOW: - Our E46 Black Tag 2.5 turns steering rack HAS ALMOST THE SAME parameters as ALL other standard E46 racks. It means things like: housing (shell), ports orientation, pinion length, pinion angle, pinion splines, threads, rod OD, mounting points, rod length and stroke ARE EXACTLY THE SAME as E46 purple, yellow, silver, blue and green tag. The only difference is obviously the number of turns. 2.5 lock to lock is a GAME CHANGER. It makes it the QUICKEST rack that you can possibly install in your BMW without heavy modifications implemented to your vehicle. Our E46 BLACK LABEL is incredibly nimble, precise and most importantly not twitchy. Even at high speeds, the steering is very predictable and easy to control. It is a life changer for drifters, racers and everyday drivers!!!   *BMW E46 - It is a direct replacement / swap for every RHD BMW E46.  *BMW E36 - It is a direct replacement for every RHD BMW E36 (please note you need to use vented inner tie rods! Cannot reuse your E36 inner ones.) *BMW E30 - It is a standard conversion procedure for every RHD BMW E30 as with installing any other E46 steering rack. If you have already installed the E46 steering rack into your E30 - it will be a direct and simple swap. No more mods and hassle required.  Important note for E46 daily drivers: If your BMW E46 is equipped with DSC (traction control), installing a quick steering rack may cause unexpected DSC or traction control intervention during sharp or quick steering inputs. Some customers choose to disable DSC, while others reprogram the DSC module to E46 M3 CSL settings to reduce unnecessary intervention. For customers wanting to retain proper factory-like DSC functionality, a dedicated plug-and-play solution is also available. Please refer to our FAQ page (https://www.steeringlpsr.com/faq)for more information about this issue and available solutions. Important note for E46 M3 owners only: Due to the design of the factory power steering pressure hose (from the pump to the rack), E46 M3 models may sometimes experience slight vibrations or a pulsing sensation in the steering. This is not a fault with the steering rack itself, but a result of the weaker hose design specific to the M3. This issue is specific to the E46 M3 and is not present on normal E46 models, E36 models or E30 models. It may occur not only with the Black Tag steering rack, but also with other quicker rack conversions such as the BMW Z3 steering rack. Please refer to our FAQ page (https://www.steeringlpsr.com/faq)for more information about this issue and recommended solutions.     - Product was developed in accordance with Australian Standards. All the work, design, material, specs etc are strictly discussed and approved by Australian Engineer. - This is a high performance product and because of a heavy abusive nature like drifting, racing etc - we offer 12 months warranty and as always - an endless after sales support.  THIS PACKAGE DOES NOT INCLUDE TIE RODS OR BOOTS     Please note that if you live in Australia every steering modification should be discussed / approved by an Australian Engineer. If you live overseas it is your responsibility to know the laws and legislations in your own country. You make all modifications at your own risk and you are liable for any damages you might cause yourself. This product should be installed by professionals.
    I see a lot of misinformation regarding steering modifications being passed around Facebook groups and forums almost daily, so I’ve decided to put together this information thread to correct the many misconceptions, and to compile a comprehensive database for steering rack swaps and power steering modifications. The
      Think there was some discussion about that rack in the steering rack rebuild thread
      Edit: Ah it was in the other steering thread: https://nam3forum.com/forums/forum/m...770#post258770
      Edit 2: karter16 damn, beat me to it!
        That's racist. A black rack will never acheive what a yellow one will. We need more DEI!!!!
          I agree, the Asian rack is better engineered but the black rack is lazy in the corners
            ahaha
              you need a brown rack to spice up things a bit or some salsa to it
                Well atf powersteering fluid looks a bit like jamaica (agua fresca)
                  Haha...nice!
                    Some pulsing mentioned here. One of the PAS steering line contains a valve. I never knew that.
