Rod Bearings You Say
    Greetings everyone
    Decided to finally do the rod bearings on the M3
    She has 102,8XX miles
    Oil changes have been Castrol TWS until 2 years ago
    switch to LM 10W-60
    My buddy lent me his garage with a lift to do this job.
    I also ordered new steering coupler , engine mounts and transmission mounts from AKG (steering coupler OEM)
    Quite a easy job to do, the DIY make it seem hard maybe over whelming.
    I just followed my own way.
    From the pictures you can see
    the rod bearing served itโ€™s purpose in its life
    Nice job man, did you use OEM or aftermarket bolts? Also what brand/model torque wrench and/or angle gauge did you use?
    Edit: I've got a 4 post lift at home (drive on type) do you see any issues doing this job with that style of lift? I don't think there would be any problems, but I don't have a full grasp of what kind of underside access is required.
      For a drive on lift it will be a little tricker to remove the front subframe. As I removed it in one piece. But you can actually still put the car on use jack stands on that lift.
      The work is still in progress. I did 4 hours of work today
      just chill with a beer no rushing. Decided to just take of one bearing today. Finish it up tomorrow
      I bought a brand new gear wrench torque wrench.
      Im using VAC bearings with the ARP studs so they are torque to stretch or torque to FT LB spec.
      I will be doing FT LB spec
        Thanks for the info, I like the beer and no rushing. My standard operating procedure is one Budlight to loosen me up for most jobs.
          I took my time and did it over 3 days total of about 10hrs, Yeah instructions are pretty overwhelming but the job was easy. (Think itโ€™s bc they list every single step) I did it on jack-stands. Hardest part for me was remove the control arms from the knuckles and torque sequence sucked since mine is an 06.
          Budget CSL MAP Conversion
            I also did it on jack stands, but it took me about a week. Worked about two hours every day since I didn't want to rush anything.
              Quickest rod bearing job I've done so far is 9 hours which felt like a safe/productive pace.
                A lift certainly makes it a more relaxing job. Nicely done.
                  anyone doing these types of jobs on the floor without a lift deserves a bottle of Blevedere... BMW should be providing that to everyone tackling this thing on the back LOL
                    Finished the job up today.
                    Runs great no noises or leaks
                    .Click image for larger version
                      Completed this job a few weeks ago. Significant wear on #2, but otherwise not too bad. Blackstone report showed elevated lead and copper, so it was time. 164k km on bearings. Even though my M3 is MY01 I had the updated bolts and torque procedure due to the block being replaced early on during the car's life due to rod bearing failure.
                      Did this job on jack stands. A lift would have made the torque sequence suck less, but I'm convinced it would have sucked nonetheless.
                      OP - that bearing is one of the worst I've ever seen. No scoring on the crank journal for that cylinder?
                        I cleaned the journal and inspected each one with a mirror.
                        no scoring on the crankshaft.
                          ๐Ÿ‘
                          Glad to hear it! Must feel good catching it in time.
