ECS has the trunk/parts for $1350 and the trunk itself for $1190. Anyone have any links to sites that may have better pricing?
Cheapest place for CSL Trunk?
InstagramTags: None
Honestly, for a Genuine BMW CSL trunk that's about as cheap as it gets. You better pull the trigger fast. I heard from a guy who works at BMW in Germany that there were only 2 CSL trunks left in the US inventory as of 3 weeks ago. Shipments for European parts is going to get significantly delayed with COVID.Originally posted by Cubieman View PostECS has the trunk/parts for $1350 and the trunk itself for $1190. Anyone have any links to sites that may have better pricing?2005 BMW M3 ZCP Black/Black - HTE Tuning | Kassel CSL DME | 280/272 Schrick Cams+P54 Followers | Dinan TBs | Bosch 550cc | Radium Fuel System | Karbonious CSL Airbox+OE Snorkel | SS V1 Stepped+Catted Sec 1+Resonated Twin Pipe+Race | 3.91, 3 stage clutch | FCM 336/600 | Vorshlag Camber Plates, RSM | Rogue ASP | AKG FCABs, SFBs | TMS Front Sway, Camber Arms, Monoball RTABs, Pullies | Mason Race Strut + X-Brace | AS 30% SSK | SPAL | Redish Plates | VAC Exhaust Hub | WPC Rod Bearings
ECS is about as bad as Shatus poop when it comes to delays.DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
Tack on customs tax to that as well. I got mine from Schmiedmann's and was super nervous that the trunk and euro bumper I ordered was going to get damaged during shipment, but it came on a palette that was very well packaged.Originally posted by heinzboehmer View Posthttps://www.schmiedmann.com/en/produ...1-00-7-895-884
Comes out to ~$1200 with shipping, but they have it in stock and ECS doesn't.2005 BMW M3 ZCP Black/Black - HTE Tuning | Kassel CSL DME | 280/272 Schrick Cams+P54 Followers | Dinan TBs | Bosch 550cc | Radium Fuel System | Karbonious CSL Airbox+OE Snorkel | SS V1 Stepped+Catted Sec 1+Resonated Twin Pipe+Race | 3.91, 3 stage clutch | FCM 336/600 | Vorshlag Camber Plates, RSM | Rogue ASP | AKG FCABs, SFBs | TMS Front Sway, Camber Arms, Monoball RTABs, Pullies | Mason Race Strut + X-Brace | AS 30% SSK | SPAL | Redish Plates | VAC Exhaust Hub | WPC Rod Bearings
APmotorsport has them for 827GBP = $1006. I contacted them to check stock.2004 Silbergrau Metallic 6MT
I have a sneaking suspicion ECS is sourcing from Schmiedmann in bulk container shipments and tacking some profit on top.'06 BMW M3 6MT Coupe - TiAg/Imola
How much does it cost (roughly) to get all the necessary bits, wiring,carpet etc.?
Would anyone happen to have a list w/ part no.s?2004 Silbergrau Metallic 6MT
This is my list, I bought a trunk back in February but have been procrastinating on getting it installed. Prices are per unit, you would need to multiply by quantities listed. Total is roughly $300 and change. US dealers cannot order the trunk liner, I ended up sourcing from Schmiedmann. You can reuse your stock one to save cost, but would either need to be okay with a hole where the tool kit is, or dremel mounting points into the csl trunk for the tool kit.OEM Electrical Connector 2 61131378149 BMW of Fairfax $2.49 OEM CSL Trunk Lining 1 51497896451 BMW of Fairfax $124.20 OEM Trunk Roundel 1 51148219237 BMW of Fairfax $38.59 OEM CSL License Plate Lamp 2 63267165646 BMW of Fairfax $12.81 OEM Lock Cylinder Gasket 1 51248223104 BMW of Fairfax $7.89 OEM Receptacle 4 61130007449 FCP Euro $3.63 OEM Plug Housing w/Lead 0.2-0.5 MM 4 61130005197 BMW of Fairfax $2.91 OEM Emblem Grommet 2 51148209932 BMW of Fairfax $0.53 OEM Blind Rivet Nut 2 46632347012 BMW of Fairfax $5.36 OEM Screw 2 51181813015 BMW of Fairfax $5.20 OEM Plug Housing 1 61136931929 BMW of Fairfax $1.91 OEM Pin Contact 2 61130006664 FCP Euro $3.63 OEM Rep Kit for Socket Housing 2 61132360043 BMW of Fairfax $10.93 '06 BMW M3 6MT Coupe - TiAg/Imola
Schmiedmann's offers a CSL trunk accessory kit. Be warned my order got held up in customs, because they had issues getting info on individual parts in the kit. It was eventually resolved, but required some hand holding.
https://www.schmiedmann.com/en/produ...t=CSLE46ACCKIT2005 BMW M3 ZCP Black/Black - HTE Tuning | Kassel CSL DME | 280/272 Schrick Cams+P54 Followers | Dinan TBs | Bosch 550cc | Radium Fuel System | Karbonious CSL Airbox+OE Snorkel | SS V1 Stepped+Catted Sec 1+Resonated Twin Pipe+Race | 3.91, 3 stage clutch | FCM 336/600 | Vorshlag Camber Plates, RSM | Rogue ASP | AKG FCABs, SFBs | TMS Front Sway, Camber Arms, Monoball RTABs, Pullies | Mason Race Strut + X-Brace | AS 30% SSK | SPAL | Redish Plates | VAC Exhaust Hub | WPC Rod Bearings
What would be considered a ballpark price to have the trunk painted/paint matched?2004 Silbergrau Metallic 6MT
Somewhere around $500-600 in my areaOriginally posted by Cubieman View PostWhat would be considered a ballpark price to have the trunk painted/paint matched?'06 BMW M3 6MT Coupe - TiAg/Imola
so would the ECS set would include all these?Originally posted by Titaniu//M View PostThis is my list, I bought a trunk back in February but have been procrastinating on getting it installed. Prices are per unit, you would need to multiply by quantities listed. Total is roughly $300 and change. US dealers cannot order the trunk liner, I ended up sourcing from Schmiedmann. You can reuse your stock one to save cost, but would either need to be okay with a hole where the tool kit is, or dremel mounting points into the csl trunk for the tool kit.OEM Electrical Connector 2 61131378149 BMW of Fairfax $2.49 OEM CSL Trunk Lining 1 51497896451 BMW of Fairfax $124.20 OEM Trunk Roundel 1 51148219237 BMW of Fairfax $38.59 OEM CSL License Plate Lamp 2 63267165646 BMW of Fairfax $12.81 OEM Lock Cylinder Gasket 1 51248223104 BMW of Fairfax $7.89 OEM Receptacle 4 61130007449 FCP Euro $3.63 OEM Plug Housing w/Lead 0.2-0.5 MM 4 61130005197 BMW of Fairfax $2.91 OEM Emblem Grommet 2 51148209932 BMW of Fairfax $0.53 OEM Blind Rivet Nut 2 46632347012 BMW of Fairfax $5.36 OEM Screw 2 51181813015 BMW of Fairfax $5.20 OEM Plug Housing 1 61136931929 BMW of Fairfax $1.91 OEM Pin Contact 2 61130006664 FCP Euro $3.63 OEM Rep Kit for Socket Housing 2 61132360043 BMW of Fairfax $10.93 Last edited by Yooliseez; 05-24-2020, 01:57 PM.
