I completely missed this was about levers and not shift knobs, shouldn't quick read a post while working.
? for those who've tried an e60 shift lever
Originally posted by T.J. View PostI have 25117527261 - the standard one.
I find the lever positioning and throw lengths to be perfect. Only complaint is the typical bmw rubbery feel which I addressed by drilling a hole and adding a bolt.2004 BMW ///M3 Carbon Black/Cinnamon 6MT
2005 BMW ///M3 Interlagos Blue/Black 6MT Dinan S3-R
So I installed the garagistic front and rear polyurethane carrier bushings, a new rod joint and new shift lever bushing. I temporarily used the original shifter lever, and it is night and day different than what it was. But my shift lever is so worn, I have to replace it. Although I am curious about TJ's "drilling a hole and adding a bolt" comment.
I also installed the 884 knob and paired it with a shift boot from turner. The leather is soft and supple and the plastic trim ring fit perfect
some pics4 PhotosLast edited by got_s54?; 11-11-2024, 07:31 AM.
Would you happen to have pictures comparing it to the factory M3 lever?
Also, would you explain what you mean by drilling a hole and adding a bolt to get rid of the rubbery feel? I might try this with my factory lever.
Originally posted by got_s54? View Post
Is the standard one only shorter in length that the shiftknob attaches to? Or is the position of the ball also different, reducing the throw slightly?
It’s slightly shorter in length, not much. Most of the throw reduction is the length below the ball
Here's a short video I made showing how much slop it has. Crazy considering it is brand new!!
Originally posted by PetrolM3 View Post
OE M3 boot is nappa. Find a used one being sold for cheap because shifter itself is worn, cut off the shifter and you have yourself a nappa boot.
I have E60 shift lever (I believe P/N 25117546373), UUC DSSR, delrin bushing and a Bimmerworld 'Lil Nicky' knob. I think the shift quality is about as good as can be without going to a full AS kit or CAE shifter, definitely like the weight and throw. Wanting to go back to stock leather and illuminated knob and will post when I replace. Due to the insane price of a new OE knob I plan to get an E36 illuminated knob (P/N 25112228742) https://www.turnermotorsport.com/p-5...uine-bmw-part/ and refit with the E46 electrical connector.
(apologies for WIP pic)
