DSC Errors: Yellow DSC and Brake Light
    So my M3 has a Yellow DSC and Brake light. I got this error about 7 months ago, i was able to clear with INPA then returned in early October. So i cleared it again, then i popped again later in October, now its popping up often.
    So now i do need to fix this issue. I scanned with INPA and it seems like brake pressure sensor 1 has a problem. When the car is cold the offset for brake circuit 1 was 7 in the red, when I turned on the it slowly creeped back down to 3.48 in the green. So I definitely seems to be an issue with what i hope is the sensor and not DSC unit.
    I looked in the brake fluid reservoir and it does look a bit dingy, last time i had brake fluid flushed was 6/22 so little over 2 years ago, maybe i just need to flush the brake fluid?
    Which is brake pressure sensor 1? Nearest to firewall, or away from firewall?
    Another question offset steering angle is in the red, from INPA live data, is that something to worry about? steering wheel seems straight.
    couple of screen shots: First Screen Shot was cold, engine not running, 2nd and 3rd was engine running it eventually settled at about 3.48
    Also a quick video pressing the brake pedal with engine on
    INPA Scan
    Code:
    E R R O R M E M O R Y
    Date: 28.10.2024 20:12:59
    ECU: DSC_MK60
    JobStatus: OKAY
    Variant: DSC_MK60
    RESULT: 1 error in error memory !
    5E20 Druck Sensor 1 elektrisch defekt
    Error counter: 6
    Logistic counter: 40
      Mileage                              271590 km
      Fahrzeuggeschwindigkeit            2.00 km/h
      Bremslichtschalter                         1.00 0/1
      Bremsfluessigkeitsschalter          0.00 0/1
      ASC/DSC_aktiv (Tasterfunktion)  1.00 0/1
      Bremsdruck erkannt                     0.00 0/1
      ABS-Regelung                              0.00 0/1
      ASC-Regelung (BMR)                  0.00 0/1
      ASC-Regelung (AMR)                  0.00 0/1
      GMR-Regelung (GMR)                  0.00 0/1
      GMR-Regelung (MMR)                  0.00 0/1
      CBC-Regelung                         0.00 0/1
      MSR-Regelung                         0.00 0/1
      TDR-Regelung                          0.00 0/1
      SDR-Regelung                         0.00 0/1
      DBC-Regelung                         0.00 0/1
      RTA aktiv                             1.00 0/1
      Run-Up Mode                           0.00 0/1
      kein passendes Fehlersymptom
      Testbedingungen erfuellt
      Fehler momentan vorhanden und bereits gespeichert
      Fehler wuerde das Aufleuchten einer Warnlampe verursachen
    Error code: 5E 20 E0 06 28 6A 17 02 09 00 04
    Start with a flush. If it comes back then yeah, the likely culprit is the sensor.
    Fortunately the sensors are expensive and extremely annoying to swap out
      There’s 2 same sensors, if you do them, do both.
      You can get in there with an open ended wrench, not exactly fun but it’s ok.
      I’ve personally had good luck with aftermarket ones from eBay here, much cheaper.
        You can also find those two sensors on any e46 2002+ with an MK60 at your local pick'n'pull and spend a few bucks.
          Thanks for the suggestions, will update this post when I get this issue resolved.
            I guess i never updated this. Ended up purchasing 2 new sensors and getting new fluid and problem is solved. Decided to replace both sensors as these were most likely original sensors. car now has 170k mi.
              When you had these lights did they turn off next time you started the car, or did they persist? I noticed mine pop up recently, then it turned off next time I started the car. I do have shadow codes for a pressure sensor and steering angle sensor, so something is likely amiss regardless.
                They can disappear and come back repeatedly until they finally die. Mine went on like this for years.
                  Did you play it safe with OE sensors or roll the dice with $15 eBay ones?
                    They would come and go. Initial time they popped up was about a year ago, it progressively got worse.
                    Played it safe and went with OE.​
                      This will sound very barbaric. On my old E46 330i, I got a DSC code one day scanned it and saw differing values. Showing a sensor was stuck. I used a brass hammer and a brass bunch. Wacked the sensor and that freed it. I saw it on the scanner in live time. I never had any issues after that. I did a full brake flush following this, it was one of the first things that happened to it after I got it going from sitting for a long time.
                      Build Thread:
