Exhaust question (Supersprint)
    I've been getting some resonance with the complete 2.5" system and i came across the video.
    Has anyone tried a bracket like this?
    Anyone know what that dual clamp is called (essentially tying both pipes together)?
    calling Bry5on
      I, too, would like a ready-to-install solution to this. I can’t believe a $5k exhaust setup does this. 🤦‍♂️
      997.1 GT3 Carrara White/Black
      C43 AMG Diamond Silver/Red​
        I am using Bry5on 's bracket and it has gotten rid of the majority of that resonance.
Name:	ssv1 brace.jpg
          Just a laser cut piece of 304 stainless joining the two exhaust clamps. Those clamps are made by evil energy if memory serves. Picked them up off of amazon.
          each bracket helped with NVH, the one that bolts to the gearbox probably the most, then the one at the headers, then the one at the back. Of the latter two, the effect was more similar than the former. DXF for the laser cut piece attached.
            i have resonance as well so im going to be ordering these brackets and i already have the clamps
              Click image for larger version  Name:	IMG_4107.jpg Views:	21 Size:	84.1 KB ID:	285286
              How can I purchase this small AND the transmission bracket from you asap, as i have zero access to the capability of doing this?
              Also, is this part (pic attached) the same stainless steel piece turned vertical, joining two staggered clamps?
              Which would be... 5 of these clamps in total with two stainless steel brackets, and the two piece transmision braket?
                Yeah this is awesome. Is this two separate pieces (a top that contours around the tranny and a bottom that connects straight to the exhaust?
                  https://www.amazon.com/dp/B08HW8ZF4Z...sin_title&th=1
                  All correct above, except that the transmission brace is three pieces. There’s a little spacer in between the two parts that looks a lot like the small bracket.
                  Let me think about a way to get you a set if you can’t get them made.
                    Me too, please.
                      Use this link to purchase all the brackets (5 total parts): https://cart.sendcutsend.com/ygpv6yonwfpq (EDIT: This link is my first design, does not fit without modification. New link coming soon)
                      You’ll just need four M8 x 16-20mm fasteners and two M8 nuts for the transmission bracket. Enjoy!
                        I'll purchase 2 sets from ya.
                        Maybe we can get a Lil GB going, to make it worth it for ya.
                          I’m in for a set as well.
                            Ordering when I get home!
                            Di you have an E9x M3?
                            I'm having this same issue there and would purchase a set for that car too!
                              I don’t, sorry! Just this wagon that’s getting all the love. I want that motor but not that car
