Engine sound
    Engine sound
    Guys, recently i've rebuided engine, done 1k miles running-in, currently have some sound at 2.5-3k like metal rattling, especially when RPMs goes on downside. Vanos was rebuilded with beisan parts, installed s62 diagrams. Only one point is not clear for me- my engine builder said that he could not change bearings in vanos gears. I've found same youtube video of my sound: https://www.youtube.com/watch?v=U8Lx452U77g Rattling only in 2.5-3k rpms, on high- no sound. Need to change vanos gears?
    Did you also have the upper chain guide tensioner arm replaced as well? (presuming you did it with the engine rebuild) if not though then I'd suspect that ahead of the bearings.
    2005 ///M3 SMG Coupe Silbergrau Metallic/CSL bucket seats
    Build Thread:
    https://nam3forum.com/forums/forum/m...e46-m3-journal
      All chain guides new, new OEM chain, redrilled Vanos oil pump, rod bearings new.
        He couldn't change or they are not needed changing?
        Why couldn't?
        But unless there is obvious axial plays in the bearing, no reason to change them.
          I posted a thread with my new engine sounds just for this reason. See here:
          We see videos all the time trying to diagnose noises. I am as guilty as anyone of these posts. The S54 is not a quiet engine. It's tough to know when it's broken. Having suffered a spun bearing a few months back, I bought a remanufactured engine from Rogue Engineering. Since I am in the break-in process, and the engine is new,
          I don't hear anything wrong with that engine.
            Re do the valve clearances and change the oil,
              Why couldn't?
              Is there any video with sound of gears? how it should be identified? I could write my engine noise but i don't think it sounds due to valve clearence cause it not increasing with RPM- only rattle in 2-3k RPM, seems like exhaust vanos gear.
                Added 3 video. Sound is heared when RPM goes downside (from 2.5-3k to idle). When oil is warming up- sounds louder. When engine is on load- no sound. Noise hearing when holding rpms stable. Could it be vanos oil pump to hub clearence? Perfectly heard in parking lot (3rd video)
                1. https://youtube.com/shorts/0Y1tfSL0c3o?feature=share
                2. https://youtube.com/shorts/9hxFIcNQiJo?feature=share
                3. https://youtube.com/shorts/NXRgSpkpNN8?feature=share
                  Will try to run engine without belt and see if something changes.
                    Update: Double checked vanos and run engine without belt- spound is due to schrick cams ant supertech springs and retainers dew to 0.25mm clearence (As my engine builders says, vanos completly silent. So will run a 5000km and recheck valve clearence to be safe. Thank you all guys.
                      It sounded normal to me to be honest. The rattle as it comes back down did not sound wrong to me
                        Any updates
                          Any updates
                          Checked sound with my engine builder- he said it due to supertech valve springs and 0.25mm schrick valve clearence. Vanos and chain completly silence. Changed oil from Liqui Moly 10w60 to Valvoline VR1 Racing 10w60 and engine is now more quiet.
