Originally posted by sapote
Moroso Aluminum Expansion Tank
Originally posted by STAATS View Post
I just shorted the wires on that so no dash light... I do eventually intend to try come up with a sensor setup so I can have it working again... but its no where near as important as the Coolant one was...
Originally posted by bryce2113 View PostJust finished adding the Moroso tank with the Moroso weld-in level sensor. Turned out great and really a pretty easy add-in if you can weld or know someone who can. Used some Deutsche connectors to use the stock wiring. Works like a charm.
This is identical to how I did mine - Deutsche connector and sensor mount location and all - only different was I left way more of a pig tail on my sensor but that was OTT of me so it doesn't look as neat as this. They really should offer this as a standard for this tank or at the very least provide it as an option. It takes all of the downsides except for "weight" out of the equation but I don't think the weight difference is huge and when you consider, providing you don't have a crash, this is basically a for life part (aside from replacing the sensor or cap as they age), then I think its not bad all round, I'm definitely happy with mine.
2005 ZCP SMG ///M3
Exactly my sentiment. I replaced the ET at the same time I replaced the rad with a KoyoRad and added the mishimoto electric fan kit (with relay). Figured if I'm going to overhaul the cooling for track reliability I'm best off going full tilt--and like you said the ET essentially has no downsides and I don't need to worry about it. I followed your lead on the sensor/bung, so thanks for the R&D so to speak.
Is anyone running this tank able to tell if it sits any lower than the OEM expansion tank does, or if the mounting bracket can be modified to sit lower? Looking to increase the clearance between my expansion tank cap and hood vents.2003 LSB/LSB 6MT Coupe | BUILDJOURNAL | CAE RACING | DMG AUTOSPORT | SUPERSPRINT | 996 BREMBO BBK | ENKEI | RAYS ENGINEERING | MOTORSPORT HARDWARE | OHLINS | GROUND CONTROL | BIMMERWORLD | TURNER MOTORSPORT | REDISH MOTORSPORT | DR VANOS | BEISAN
Originally posted by HighOnLSB View PostIs anyone running this tank able to tell if it sits any lower than the OEM expansion tank does, or if the mounting bracket can be modified to sit lower? Looking to increase the clearance between my expansion tank cap and hood vents.
Hey mate - it doesn't sit any lower and uses the exact same mounting bracket etc as the stock tank so doesn't give you any more flexibility with regards to clearance over the stock tank. like if you could modify the bracket to make this sit lower you could equally achieve that with the stock tank. I'd say you are likely stuck in the space of having to custom fabricate a tank depending on how much clearance you need.2003 LSB/LSB 6MT Coupe | BUILDJOURNAL | CAE RACING | DMG AUTOSPORT | SUPERSPRINT | 996 BREMBO BBK | ENKEI | RAYS ENGINEERING | MOTORSPORT HARDWARE | OHLINS | GROUND CONTROL | BIMMERWORLD | TURNER MOTORSPORT | REDISH MOTORSPORT | DR VANOS | BEISAN
