FCM Move - Summer Special - Crucial Ride Harmony Concepts - Miata For Sale
    I appreciate this type of bespoke service that results in top notch quality. Have you done a flat ride suspension for the e39 M5?
      Thank you. It's because I go into so much detail that knobs and reservoirs and guesswork is largely removed. The variables you can and ought to adjust then actually matter (in particular tire pressures, sway bar settings, alignment, and ride height). Plus, the beautiful ability to make subtle balance changes with packers / bump stop spacers (in particular on the rear dampers which are very readily-accessible). With an essentially neutral-handling setup, one or two packers under a rear bump stops are magical!
      Yes, during 2020 I worked with Brett, an E39 M5 owner here in Norcal, to apply Ride Harmony (and some Race Synergy!) to his M5. He sprung for the FCM Elite Stage 3 Ultimate. 😉 It was the first M5 I'd done a build for. He gave me an update in November 2022 (the screenshot below).
      Click image for larger version  Name:	Brett E39 M5 testimonial Screenshot 2025-08-06 at 16.44.59.jpg Views:	0 Size:	67.5 KB ID:	314726
      Flat Ride is always the foundation unless and until I work on an F1 car (and even then I'm still tempted to see what's possible with Flat Ride!).
      Shaikh Jalal Ahmad
      Suspension Decoder @ Fat Cat Motorsports, Inc.
      Youtube: Suspension Truth
      FCM E46 M3 Ride Harmonizer spreadsheet
        Have you worked with a Z4M (Roadster if that matters)? It seems like most solutions other than stock springs cause various issues due to the limited travel of this car.
          Yes, I did a setup in 2017 for a gent up in Canada. This was an FCM Elite Stage 3, prior to the latest enhancements with Stage 3 Ultimate and now the more efficient / higher-grip Ripple Reducer. Ride frequencies were in the 1.9 / 2.0 Hz range, a dual-purpose streetable track setup (or trackable street setup...!). He seemed very pleased:
          Click image for larger version  Name:	FCM_Testimonial_KBO_Igor_BMW_Z4M.png Views:	0 Size:	33.2 KB ID:	314843
          So definitely possible to use a coil-over (and I'd say desirable, if / when implemented with Ride Harmony as the foundation) on the Z4M to improve performance and also have good ride. Dare I say, perhaps even better-than-stock ride, depending on the spring rates / ride frequencies we select during our consultation process.
          Shaikh Jalal Ahmad
