Originally posted by nextelbuddy
Best CSL Airbox Setup?
But you said you needed an HP DME?Originally posted by DepthPatrol View Post
Appreciate the offer but I don’t plan on changing from stock setup on exhaust system.
Any donor DME will need at least an EWS delete so I don't know that you will be able to just have a plug and play DME.
You could buy one of those and use a really cheap and easy to use program (binary modification tool from ecuworx.co.uk) to make the necessary changes.
Additionally you could ship it no any number of places for changes and you could also have a tuner make the changes remotely if you purchase a KDCAN cable.2004 Silbergrau Metallic 6MT
I can put whatever you want on it is what I'm saying. If you want something deleted I can delete it. If you want stock exhaust tune no problem I can do that too. The main part is the HP DME. Anything else can be changed on the actual DME tuneOriginally posted by DepthPatrol View Post
The tune that I provide on here will be very sufficient regardless of deleted cat or no deleted cat and you will be able to drive fine without having to get tuned immediately from a tuner. But eventually you'll want to get tuned if you want to tweak as much power as you want on a dyno.
COVID-19’s fitting on the brake booster line. Was pleasantly surprised that it all worked right out of the box without any of the drivability issues most people with carbon airboxes seem to encounterOriginally posted by 4getr34 View PostI'll be getting my karbonius box in a few weeks. I'm thinking of going with Kassel MAP/IAT CSL installation kit on air rail- anyone else has this setup? how do you like it? what other MAP options exist?2002 TiAg M3 Coupe (SMG to 6spd), 2003 Jet Black M5
Sorry if this is a stupid question.
Any noticeable mileage changes for highway for the airbox. improvement, reduction, the same?
Any difference in fuel mileage with MAP vs Alpha N if anyone has done both?
I am not expecting a Toyota Prius, Just want to make sure it is similar or close to same for stock. I drive my car to Road Atlanta, and use it day to day.Build Thread:
About the same.Originally posted by samthejam View PostSorry if this is a stupid question.
I am not expecting a Toyota Prius, Just want to make sure it is similar or close to same for stock. I drive my car to Road Atlanta, and use it day to day.Instagram: @logicalconclusion
I'm using this setup, as well as Kassel's HP DME tune. It was easy to install and it's stealthy. I did not notice any drivability issues.Originally posted by 4getr34 View PostI'll be getting my karbonius box in a few weeks. I'm thinking of going with Kassel MAP/IAT CSL installation kit on air rail- anyone else has this setup? how do you like it? what other MAP options exist?"your BMW has how many miles!?"
2007 GX470
build/journal
ig: @zzyzx85
Have there been any issues with the haimus boxes since the initial switch over in company name, etc? Pricing between haimus with shipping and karbonius is nearly the same now. Small thing but I like that the haimus box doesn't have that additional roughly 2" diameter inlet on it.
Also ECS tuning is listing them as shipped from the manufacturer. Anyone know if that means it's warehoused overseas and I'm going to get a tarriff surprise?Last edited by 3staxontheradio; 10-25-2025, 05:39 PM.
I had the karbonius with oem CSL flap, IAT + MAF, HTE tune and I really dislike it. I let the flap open 100% because I had a 2001. Probably going MAP next time doing this.Instagram : @gc.m3sg
2023 M3C Xdrive British Racing Green
2003.5 M3 Silver Grey 6 speed
______________________________________________
Miles End Composite CF CSL front bumper/Diffuser/Trunk
ST Suspension/CSL Rotors/Full Magnaflow exhaust
BBS RSII/Avant-Garde CSL Reps
If you are experiencing a sluggish throttle, you simply need to tune your car. See Pasha's tuning thread, I used his method multiple times to tune the air/fuel ratios and my car became on another level, way better than any OTS tuner can give you.Originally posted by Slideways View Post
In the 2-3K RPM range, are you having a lag in throttle response when you rev match? I noticed this in the street test video and on a Z4M with airbox I recently drove.
Go map and then tune your car by logging data using pasha's method, it's here somewhere. He's also in California now, so, if you're from California - i'm pretty sure you could convince one of the coolest S54 guys to look at it.Originally posted by M3LSB.Gab View PostI had the karbonius with oem CSL flap, IAT + MAF, HTE tune and I really dislike it. I let the flap open 100% because I had a 2001. Probably going MAP next time doing this.
