TCK & rear shock bolt
    TCK supplies a washer that is to be used with the rear shock bolt. When this washer is used the bolt does not have full thread engagement.
    I *think* they want you to use the washer because if you don't when you tighten the bolt it wants to spin the "plate" on the inner side of the shock possibility distorting the bushing.
    Any thoughts on this would be great, I tend to overthink simple things but I don't like loosing a couple threads when there isnt that many to begin with.
    I may try to find a thinner washer but most this size are generally the same thickness.
ID:	326060 Click image for larger version
ID:	326061 Click image for larger version
    Personally, I wouldn't worry over that 1 unused thread. Order a slightly longer 12.9 bolt off McMaster Carr if it bothers you.
    2003.5 SG/Grey
      I would go for a longer bolt.
      rule of thumb is the bolt is at least long enough that there are three full threads past the joint.
        I experienced the same issue which I posted about here.
        I got a longer bolt here.
        🔹 2001 M3 Laguna Seca Blue
        Instagram: link
        Build thread: link
          Nice, I grab one, thanks! I put a thinner washer on and missing about 1 thread still.
            Yeah for a critical suspension bolt like that might as well do it right. Get a proper washer with the appropriate hardness for a 10.9 bolt.
            Instagram: link
            Build thread: link
              I ordered the bolts/washers, loving that website as well!
