DMG Autosport not fulfilling order
    I had this same issue years ago for a standard strut tower bar after the stock one broke on me. It was months of back and forth before I got it...
      My main issue is my towers cracked along the holes and I didn't do a great job grinding the welds. I had to grind welds on the top and bottom, unfortunately I went too far in some areas.
      I don't have cracks anymore but I do have reduced metal thickness in areas that are near the holes unfortunately. I really feel I need a flat footing on top and plates on the bottom at this point.
      Edit: Maybe I'll order the spacers for my towers (even though they don't have the bumps) and use with the stock bar until I can maybe find a suitable alternative in down the line. More surface area on the tops of the towers.
      I ordered these and they fit beautifully.
        https://ebay.us/m/dRbQbe
        Ordered, thank you, seems like a good setup with compromised towers and stock bar. Now my problem will be the studs on my camber plates won't be long enough, always something.
          So no updates?
          2004 Dinan S3-R M3
          2023 X3M Competition
            So no updates?
            Absolutely none.
            '05 ///M3 Mysticblau Metallic / Grey Nappa 6MT
            '24
            Audi RS5 Nardo Grey / Black
