I’ve successfully removed bell housing & engine mounts. Engine is on hoist. The engine is separated about 1-2 inches from transmission. Nothings caught up on dowl pins. I’m having a hard time getting this beast out. I can rotate engine a pretty good amount, from a visual standpoint the flywheel rotates/follows how I rotate the engine. Ive researched as much as I can. I believe the transmission shaft is stuck in pilot bearing. If there’s any tips please let me know thank you.
To clarify this engine is still in engine bay Incase of any confusion.
