Heavy Duty exhaust hangers?
    So one disadvantage of a titanium exhaust is it literally vibrates itself apart at the welds. Do you think more solid mounts could help this?
    No— would be far, far worse for it.
      Originally posted by DanAvoN7 View Post
      I recommend replacing with a set of Genuine OE BMW exhaust hangers. They aren't cheap at ~$48-$53 per hanger but these hold up well and will last a good amount of time with the weight of the stock section3. I've seen a few cars running the cheap OEM CRP, HJS, etc. hangers and they always failed not long after install. With a lightweight aftermarket exhaust the hangers won't see as much stress so the cheaper alternatives may hold up...
      Good to know, was just going to install new HJS hangers I have laying around on my SGT SCZA muffler while its up on the air. That muffler is probably 45lbs. Are they (HJS) really THAT bad? My OE hangers aren't too bad, maybe I should just leave them on if the HJS are inferior.
        The Scorza made version of that muffler was 25 lbs.
          I weighed it at 35-36 without the tips. Was over estimating the weight with the tips, but I'll bet the 4 double wall tips weigh at least 8lbs. I never weighed it on the scale with the tips attached.
            Interesting that it's so different for supposedly the same product.
              https://statusgruppe.com/product/bmw...ler-section-3/
              They list the weight at 35lb, but that is definitely without tips! Those tips I have felt like they could be pushing 10lbs possibly if not more.l, but they are the double walled style. Not exactly a light muffler, but still much lighter than stock.
                Well they do state that it's a revised version with the following changes: We updated the internals (now stainless steel/ fiberglass packed), the Hanger System
                So yep that'll add some weight. Plus who knows if the material is the same.
                  Thread revival but I’ve gone through 3 sets of genuine BMW exhaust hangers now (exhaust is fettled but stock).
                  First set was when I bought the car on 75,000 miles / 16 years old. Second set was after a Nurburgring trip at circa 95,000 miles / 18 years old and the third was after an Anglesey track day at circa 105,000 miles / 19 years old.
                  The OE exhaust hangers seem to handle road driving fine but after I’ve put the car through it’s paces on track they fail.
                  My garage recommended Powerflex replacement bushes, however I wanted to check whether others running the stock exhaust system and track their car have also had this issue?
                  2002 BMW E46 M3 Coupé
                  2005 Porsche 911 (997.1) Carrera S
                    You sure you're not installing them backwards? Mine last ~75,000 miles/set, with extensive track use.
                      I think an RE mount on the passenger side only is a good compromise all around. I had to do this simply because my aftermarket muffler would run into the evap box every so often.
                      At one point I ran all 3 RE mounts and that is overkill imo not to mention the notable increase in NVH.
                        Joker I’ll ask my mechanic.
                        Do you have a stock backbox?
                          I wasn't kidding-- they're directional, and lots of people install them backwards.
                          I have the SS street-- which is only ~3 lbs lighter than stock.
                          Note how the part where it bolts to the muffler is closer to the back of the hanger. You can force it the other way around, but they fail faster if you do.
                            My stock ones were completely clapped out somewhere around 60 or 70k miles, the muffler was flying around. I replaced them with some "oe equivalent" ones and they were toast in like 2k miles already! So I bit the bullet and bought OE again, but filled the gaps with a soft silicone RTV. They are holding up great now. Firm but still compliant.
                              FCP sells hangers made by HJS. Does anyone know if they’re actually OEM and if they last as long as OE hangers?
                              997.1 GT3 Carrara White/Black
                              C43 AMG Diamond Silver/Red​
                                No, avoid the HJS, only genuine BMW for these.
