Failed vanos test
    New charged ACC won't help the pump to have higher P.
    Why low P?
    * bad leak on internal seals
    * pump output is low: check for sticky pump pistons moving inside the disk; no missing or broken springs inside piston; check for any plays between disk and center shaft.
    Btw, remove all 12 bolts holding the cam sleeves, clean the threads and add medium strength Loctite on threads to avoid chopped bolts and bent valves.
      Why low P?
      looks like it’s removal of vanos to figure out pump piston etc.
      when i rebuild vanos, I’ll replace cam sprocket bolts and upper timing chain guide.
      I have a spare vanos unit that I’ll rebuild first and then swap over when I get the time
        Originally posted by M3kob View Post
        lwhen i rebuild vanos, I’ll replace cam sprocket bolts and upper timing chain guide.
        Why cam sprocket bolts? They almost never gone bad.
          I was reading a guide and sure mentioned removing them one by
          Cleaning up and replacing. Some had a renewed bolt
            I'm not sure we're talking the same bolts. What could go wrong if the bolts not replaced?
              Right a bit of an update….
              swapped out vanos for a rebuilt one from a company, checked timing etc with genuine bmw timing tool and put it all
              back together, but still fails to pass vanos tests.
              New vanos also came with new solenoid pack and tested before shipment.
                With a known good vanos and solenoids, I feel like that only leaves the DME, maybe the wiring harness itself. Though I would think there would be some sort of error stored if that was the case
                Perhaps check continuity between the solenoid end and DME end of each pin?
                  There’s zero fault codes in the dme which always makes it harder. I just remembered even with maf disconnected I didn’t have a code or a eml light on. The car does have a tune from Evolve with rev match
                  Need to find wiring diagram so I can check continuity of cable
                    Right, I found a test file for Tool32 courtesy of Tomba, results attached.
                    It seems to give different outcome to my other test. Would you say this is ok or I should check timing again?
                    Thanks again
                    s54 vanos test tool32 results2.txt
                      To make debugging easier, I would think get back to the stock coded DME firmware is the right move. Sort the problem out then you can play with the engine tune firmware.
                      To check the vanos solenoid wiring: there are 4 wires from DME for controlling 4 solenoids.
                      DME 52pin black connector: check resistance from each of these pins to engine gnd: p50, 4, 43, and p44, with the connector unplugged from dme. A better check is to apply 12v directly to each pin, for 2 sec to avoid overheat the solenoid, and listen for solenoid clicking.
                        Thanks. Strange it passed tests with Tool32
