Failed vanos test
Last edited by oceansize; 04-14-2026, 04:19 AM.2003 | 3.91 | CMP Subframe & RTAB Bushings | SMG (Relocated & Rebuilt) | ESS Gen 3 Supercharger | Redish | Beisan | GC Coilovers & ARCAs | Imola Interior | RE Rasp | RE Diablo | Storm Motorwerks Paddles | Will ZCPM3 Shift Knob | Apex ARC-8 19x9, 19x9.5 | Sony XAV-AX5000 | BAVSOUND | CSL & 255 SMG Upgrades | Tiag | Vert w/Hardtop
I believe coolant temp has to be >75C and oil temp >40C. Other two conditions are no faults stored and engine at idle.Originally posted by maupineda View PostVanos test will not start until oil temp is >75C.
when I had a bad Vanos, when cold it would be 115bar but dropped to 40bar when hot.
did you let the oil to fully warm up?
I didn’t today when checking pressure, prior to that I did as the procedure won’t start before coolant above 75degC and oil above 40degC. Didn’t have enough time today with the car to get it up to temp, will try tomorrow/Friday and check pressure on gaugeOriginally posted by maupineda View PostVanos test will not start until oil temp is >75C.
UPDATEOriginally posted by sapote View Post
* cam timing was wrong. need to double check the timing setting with VC off.
* vanos solenoid pack or its wirings.
* cam sensor signals
Managed to warm it up today and monitor pressure as oil got hotter. Pressure drops as oil temp gets warmer:
cold : 1500psi
49degC : 1100
63degC : 1000
71degC : 1000
80degC : 900
90degC : 900
900 psi is too low. Was anyone working on the vanos and the pump disk recently?Originally posted by M3kob View Post
UPDATE
cold : 1500psi
49degC : 1100
63degC : 1000
71degC : 1000
80degC : 900
90degC : 900
not as far as I know.Originally posted by sapote View Post
I purchased car in September 2025 and barely done any miles since then. Been stalling interior, quarter as seals etc. Vanos looks original. As mentioned I’ve got a recharged accumulator so will try and fit that tomorrow and see if it helps but I’m guessing it’s going to be vanos rebuild
