Originally posted by terra
61319122700 (US post 2001/09) - clutch switch module, 4 PINS connected (12V/GND/signal to DME via gear indicator switch + signal to EWS) - located on clutch cylinder
61318363710 (US pre 2001/09) - 3 PINS connected (12V/GND/signal to DME via gear indicator switch)
61318381612 (US pre 2001/09) - clutch switch, acts as STARTLOCK, 3 PIN(12V/GND/signal to EWS module)
I think as far as I can tell all the sensor outputs are the same, just the post 2001 700 module is an all-in-one.
So for pre 2001 or somebody that used a pre-2001 clutch master cyl like in my car you'll need 710 and 612 plus 61116911072 which is a Y connector that plugs into both 710 and 612 modules above. (blue = cruise, red/purple = startlock)
Here is a picture of a Z3M (MSS5x), you can see the two switches clearly (red on the left of the pedal, purple on the right)
