"Budget" lightweight battery
    I've been very interested in getting a lithium battery for the car to drop a signifiant amount of weight. I've held off because my AGM battery is in good health and a $1000 for a H6 size battery is a lot.
    I know many forum members are big fans of a couple brands. After doing some evening research I decided to purchase a "budget" brand lithium battery. The specs are what I was looking for.
    It claims to have an intelligent BMS, but it's not likely to be on par with the top shelf brands. I will say that I work in an industry that uses Lithium batteries and the tech as well as pricing has
    changed a lot in the past 2-3 years.
    As you can see in the photos it's the Mighty Max H6. I paid $279.
    I installed it and weighed both the old AGM battery and this new lithium.
    Might Max H6 weighs 14 lbs
    Duralast Platinum AGM is 48 lbs
    34 lbs of weight savings for $279 seems pretty good to me.
    I also like that it fits exactly like a standard battery and doesn't need a new bracket.
    Lemme know what y'all think.​​
    Very appealing at that price point.
    Would removing that much weight from the rear right side of the car throw off the balance?
      On a street car? No.
      On a corner-balanced car? Yes.
        Looks like the H5 spec version at 700cca and 9.2 pounds is $230.
        Wonder if that would get the job done?
          It probably would. But for $40 and 3lb claimed weight gain you get twice the Ah and reserve. And it fits perfectly in the battery tray.
            Who makes the battery and where is it made?
            I'm asking from a "will it suddenly catch fire" perspective 🙂
            If it's a quality piece, that is extremely appealing. Nice find.
              Braille had a sale on batteries recently FWIW. I picked up a group size 35 lithium ion battery for $599.
                FWIW, here is what AI had to say about the Mighty Max batteries:
                Mighty Max Batteries is a US-based distributor that sources and imports its batteries from manufacturing facilities in China. They are very well-established in the deep-cycle, solar, and power sports markets.
                Regarding safety, these specific automotive models use Lithium Iron Phosphate (LiFePO4) chemistry. LiFePO4 is inherently stable and is the safest lithium chemistry available for vehicle applications, meaning the risk of thermal runaway (fires) is exceptionally low. They also feature a built-in Battery Management System (BMS) to protect against overcharging, over-discharging, and short circuits.
                However, the low cost reflects the use of mass-produced, generic imported cells and standard BMS boards. While they work well in low-draw or stationary applications, high-performance automotive environments are much harsher. The primary concern with budget lithium car batteries is not safety, but longevity and reliability. The internal busbars, cell packaging, and BMS must withstand intense vibrations, high-amp alternator charging, and heat. If you are preparing the car for hard driving, a cheaper internal construction is more prone to early cell failure or BMS faults than a purpose-built racing or performance battery.
                  I would also be curious about the longevity and expected life of an LiFePO4 battery, especially for a daily driver. I have gotten 9, 10, 11 years out of an OEM battery a number of times (these were simpler and "older" cars, IE my '14 EvoX and '15 Camaro Z28, among others). For sure German cars are more demanding of batteries, not to mention newer cars, and I've not had any of my E46s long enough to see how the batteries perform a decade out, but this is of interest.
                  If I can get 7, 8 or more years out of a lead acid battery, and have to replace an LiFePO4 after just a few years, the cost savings likely disappear, though the weight savings of course remain. For a daily driver though it would be harder to justify.
                    Antigravity have been great for me. Expensive but haven't had any issues for the past 2 years I have had them in my 911's.
                      LiFePO4 is a safe chemistry as far as lithium goes. More resilient and far less likely to explode than other chemistries.
                      That said a Mighty Max lead acid battery is the only brand I've had that failed super early in a vehicle of mine after just 2 years, whereas I usually get 8-10 years out of them. Who knows if that was a dud or speaks to their quality.
                        Im excited to see how it works out. My situation may differ from some. The car is not a daily and is garage kept. I can easily keep it on tender during some of the longer periods in which it’s not driven.
                        First test starts now. I haven’t driven it since last week and I gotta travel for work until Memorial Day. So it’s going to sit without a tender for 3 weeks. I’ll test the charge when I get back.
                          Short term update-
                          So far so good. Car sat for about 3 weeks while I was out of town. Held charge without a tender. Drove it to my local shop for a bushing overhaul and it sat several days over there.
                          To this point, albeit a short sample, it appears to be doing its job.
                            Originally posted by theOracle View Post
                            Short term update-
                            Thats great! Thanks for the feedback. For myself im going to keep using a normal battery for now until things get back to a NEW normal and hopefully someone will start importing proper Li batteries.............
                              Short term update-
                              Good to hear. You said it fits right under the OEM bracket and screw/pad combo?
