"Budget" lightweight battery
    I've been very interested in getting a lithium battery for the car to drop a signifiant amount of weight. I've held off because my AGM battery is in good health and a $1000 for a H6 size battery is a lot.
    I know many forum members are big fans of a couple brands. After doing some evening research I decided to purchase a "budget" brand lithium battery. The specs are what I was looking for.
    It claims to have an intelligent BMS, but it's not likely to be on par with the top shelf brands. I will say that I work in an industry that uses Lithium batteries and the tech as well as pricing has
    changed a lot in the past 2-3 years.
    As you can see in the photos it's the Mighty Max H6. I paid $279.
    I installed it and weighed both the old AGM battery and this new lithium.
    Might Max H6 weighs 14 lbs
    Duralast Platinum AGM is 48 lbs
    34 lbs of weight savings for $279 seems pretty good to me.
    I also like that it fits exactly like a standard battery and doesn't need a new bracket.
    Lemme know what y'all think.​​
    Very appealing at that price point.
    Would removing that much weight from the rear right side of the car throw off the balance?
      On a street car? No.
      On a corner-balanced car? Yes.
        Looks like the H5 spec version at 700cca and 9.2 pounds is $230.
        Wonder if that would get the job done?
          It probably would. But for $40 and 3lb claimed weight gain you get twice the Ah and reserve. And it fits perfectly in the battery tray.
            Who makes the battery and where is it made?
            I'm asking from a "will it suddenly catch fire" perspective 🙂
            If it's a quality piece, that is extremely appealing. Nice find.
              Braille had a sale on batteries recently FWIW. I picked up a group size 35 lithium ion battery for $599.
                FWIW, here is what AI had to say about the Mighty Max batteries:
                Mighty Max Batteries is a US-based distributor that sources and imports its batteries from manufacturing facilities in China. They are very well-established in the deep-cycle, solar, and power sports markets.
                Regarding safety, these specific automotive models use Lithium Iron Phosphate (LiFePO4) chemistry. LiFePO4 is inherently stable and is the safest lithium chemistry available for vehicle applications, meaning the risk of thermal runaway (fires) is exceptionally low. They also feature a built-in Battery Management System (BMS) to protect against overcharging, over-discharging, and short circuits.
                However, the low cost reflects the use of mass-produced, generic imported cells and standard BMS boards. While they work well in low-draw or stationary applications, high-performance automotive environments are much harsher. The primary concern with budget lithium car batteries is not safety, but longevity and reliability. The internal busbars, cell packaging, and BMS must withstand intense vibrations, high-amp alternator charging, and heat. If you are preparing the car for hard driving, a cheaper internal construction is more prone to early cell failure or BMS faults than a purpose-built racing or performance battery.
