What's up guys! I have an issue that I thought was resolved multiple times now, but it continues. Take a look below -
Overview -
Video showing the issue - https://drive.google.com/file/d/1i2P...usp=drive_link
Related changes for your info -
- Koni yellow suspension and H&R springs (26k miles old)
- Control arms and with poly bushings replaced (36k miles old)
- Tie rods replaced (38k old)
- Steering rack replaced (38k old)
- Wheel and tire setup: Stock 18’s staggered setup, stock sized brand new Michelin PS4’s - F: 33psi, R: 36 psi
- No camber kit or anything else aftermarket on suspension
Summary of problem -
Shimmy in steering wheel came once installing spacers that will not go away - occurs around 50-80mph - This is still happening even with a brand new Turner Motorsport Flush kit.
This all started when I put 15mm spacers on the front, and 10mm on the rear. I bought a set of used spacers from another e46 M3 guy for $100 (Macht Schnell) with extended bolts and threw them on. I got a wicked shimmy in the steering wheel from this. From there, this is the diagnosis and solutions I’ve gone through.
Current setup -
Front: 15mm Turner Motorsport Spacer, 39mm extended bolts, Stock 18” style 67 Wheel on brand new PS4’s at stock tire size
Rear: 12.5mm Turner Motorsport Spacer, 39mm extended bolts, Stock 18” style 67 wheel on brand new PS4’s at stock tire size
Steps I’ve taken so far -
Step 1 - Install Macht Schnell Spacers 15mm F, 10mm R
- 15mm front spacers: the 43mm extended bolts I got for these would NOT fit on my hub. Every time I tried to tighten these down they would not fit the 15mm spacer with my wheel. They seemed to long for the hub and would essentially bottom out on the back of the hub. The 39mm fit well, and with 6 turns + torquing I felt safe with this. I also measured them and they measured out correctly for the additional size.
- Any wheel play in front wheels side to side? NO. Perfectly in-sync with steering wheel
- How are the tires? Inner bands pretty worn, and tires were 6 years old. REPLACED.
- New PS4 tires and static balanced - shimmy still exists
Step 2 - run tires at 42 psi - get car to 70mph and see if the shimmy is gone.
- If it goes then it’s dynamic imbalance and you need to get the wheels Force balanced - found from this guy on YouTube with a great explanation - https://www.youtube.com/watch?v=U9INhvG3TE4
Result: Shimmy was gone! So Force balance will seem to fix this issue based on this youtube video
Step 3 - Dynamic balance the wheels, run at normal PSI (33/36psi)
Result: Shimmy got better, but still there
Step 4- Pull the wheels. Do the paper test on the spacers on their respective wheel. Check for play in the hub as well, these things should be TIGHT
Result: Steering rack, everything else in the suspension system seems totally fine. Not sure / not confident in used spacers. To eliminate this variable, I bought the Turner Motorsport Perfect flush kit
Step 5 - Install Turner Motorsport perfect flush kit (15mm in front, 12.5mm in rear)
- Did the paper test on the used spacers vs new Turner spacers - it did seem like perhaps the old spacers were warped ever so slightly as the paper test was a bit easier in some areas on the Macht Schnell front spacers.
- On the front hubs: when moving the spacer up and down on the hub it did seem that there was SLIGHT movement which I could hear, but it was so slight I thought perhaps this was normal as the spacer needs perhaps a tiny bit of room for heat expansion, etc. Didn’t seem to do this side to side though - tried to capture on video but didn’t really get the sound - https://drive.google.com/file/d/1e1p...usp=drive_link
- Ran 39mm extended bolts front to back again as the 43mm in the front just would not fit properly and could not be tightened all the way down
- Had the front wheels re-force balanced as I found the passenger front wheel to not have wheel weights weirdly as if it lost them. Turns out yes, the passenger front needed a .75 which they installed, driver’s side was fine.
- Shimmy seemed to get slightly better but still not 100% as it was before spacers. This video is the latest shimmy with the Turner spacers installed: https://drive.google.com/file/d/1i2P...usp=drive_link
Next experiments -
Step 6- Fill front tires to 42 psi to see if it resolves the issue
- Will try this today
Main thoughts for the culprit -
- Bent front wheel(s) that are balancing no problem, but because of the spacers is showing itself clearly where as without spacers it’s fine?
- Potential wheel bearing issue?
Any help / advice would be highly appreciated, I’m going nuts trying to figure this out! Thank you guys so much in advance!!
Overview -
Current setup -
Next experiments -
