MSS54 DS2 Tool: FREE - DME tune, program, flash counter, codes, adaptions, etc
    Hi all,
    For those of you who've been following on my journal you'll have known this is coming
    For many years those of us with E46 M3's have had to pay for tools to flash our DMEs. No longer, this app is FREE to use: Freeware license here
    Disclaimer
    Using any tool to write to/modify your DME is not free of risk. You should always ensure that you take a full backup of your DME prior to doing anything else (the app will try it's best to get you to do this).
    This is version 1.1.0 of a tool developed by an individual (me). I've done my best to make it robust and reliable and test it as much as possible. Others have also helped with testing.
    THIS DOES NOT MEAN IT IS GUARANTEED TO BE DEFECT FREE!
    Acknowledgements
    heinzboehmer , Bry5on and George Hill have been instrumental in helping to test this as well as providing significant amounts of extremely useful feedback that has helped make this a much better tool that I could have achieved alone. I am very grateful to them for the time and effort that they have put into making this a reality.
    Download Link:https://github.com/karter16/MSS54-DS...ublic/releases
    FTDI D2xx Driver Setup Instructions: https://github.com/karter16/MSS54-DS...X-driver-setup (if you already have another flashing software setup you shouldn't need this)
    OBDII Interface and Connection Troubleshooting: https://github.com/karter16/MSS54-DS...roubleshooting
    Explanation of MSS54 Memory Layout and Read/Write Types: https://github.com/karter16/MSS54-DS...ad-Write-Types
    Reporting Issues: Please report any issues via the GitHub repo: https://github.com/karter16/MSS54-DS...lic/issues/new so that we can keep everything in one place (do feel free to discuss issues in this thread as well, it would just be very helpful if you enter into Github so I have a nice list)
    System Requirements
    - The app runs on Windows 10/11 (x86, x64 and ARM64 (works great on a VM on Apple Silicon)) with the .Net 8.0 Desktop Runtime
    - The app supports OBD2 (FTDI D2xx driver) cables, and also supports COM.
    Key Features/Screenshots
    Connect Screen
    - Guided connection
    - Auto-detection of cable, connection to car, Ignition, etc.
    - Auto-connect when cable found, and ignition on.
    Click image for larger version  Name:	1-Connect Screen.png Views:	0 Size:	236.2 KB ID:	355302
    DME Info Screen
    - Key DME info (VIN, Serial, Production Data, Variant, etc. Summary of any data integrity, errors, etc.
    - Flash Counter
    - Logistics info (these are the bootloader / program / data numbers that are frequently referred to)
    - AIF records
    Click image for larger version  Name:	2-DME Info Screen.png Views:	0 Size:	147.6 KB ID:	355306
    Error Memory
    - Read Error Memory
    - Read Shadow Error Memory
    - View detailed info about errors as well as interpretations of the exact error types for that error.
    - Export report of errors for sharing
    - Clear Error Memory
    Click image for larger version  Name:	3-Error memory Screen.png Views:	0 Size:	213.2 KB ID:	355304
    Adaptions
    - Read Adaptions and view interpreted data
    - Export Adaptions for sharing
    - Clear Adaptions (either all at once or specific categories only)
    Click image for larger version  Name:	4-Adaptions Screen.png Views:	0 Size:	236.4 KB ID:	355308
    Live Values
    - View live values in app
    - Choose values to log to CSV for import into log viewers, etc.
    - Save log sets in app so you can easily log the same data points over multiple runs.
    Click image for larger version  Name:	Screenshot 2026-05-22 at 7.19.15 PM.png Views:	0 Size:	202.9 KB ID:	356128
    DME Read
    - Read out current Tune off your DME
    - Read out current Full binary off your DME
    Click image for larger version  Name:	5-DME Read Screen.png Views:	0 Size:	86.5 KB ID:	355303
    DME Programming
    - Write Tune (.bin or .0da)
    - Write Program (.bin or .0pa)
    - Clear Flash Counter
    - Insert AIF Record (free type, copy existing, insert from another binary file)
    - EWS Re-sync (for when a paired DME and EWS3 module have got their rolling codes out of sync).
    - Recycle DME (aka virginization. This entirely wipes the Service Info and Adaptions blocks. If you don't already understand what this is and why you might want it then don't go near this, if you try to you're going to have a lot of pop-up confirmations to deal with)
    Click image for larger version  Name:	6-DME Programming Screen.png Views:	0 Size:	176.0 KB ID:	355307
    History
    - The app captures everything you do as an item in the history, indexed to the DME serial number. This means you have full history of what you've done, and means you can restore to any point in that history.
    Click image for larger version  Name:	8-History Screen.png Views:	0 Size:	315.8 KB ID:	355309
    Worth saying as well that this is version 1 of an app that hopefully becomes better and better over time. All feedback is welcome, and feedback about what could be better/what sucks/what isn't clear/etc. is most useful to help improve the app. Please if there's anything you don't understand, think could be clearer or better, or features you'd like to see please shout out!
      Keep kicking A$$..... this is awesome
        This is absolutely amazing! Will downoad it this weekend!
        Thank you so much for doing this for the rest of us schleps.
          Thank you!!
            can we add bmwlogger type of features too?
              Yes that's definitely something that could be added - I wasn't sure if there was any demand for that given there are other free apps out there that do DS2 logging, but certainly something that could be done. In fact the app currently uses the same mechanism to retrieve and display UB (battery voltage), so the basic proof is there already.
                Thank you!
                  Very cool
                  Curious how you got the D2XX drivers to work with Windows ARM? I have had no luck getting them to work
                    That Adaptation piece is awesome! Amazing tool!
                    Build Thread:
                      This is so epic man
                        Very cool
                        Just with the ARM (Windows Desktop) driver in the first row of the first table on this page: https://ftdichip.com/drivers/d2xx-drivers/
                        It was necessary for me to install them manually via Device Manager, but has been flawless since I did that.
                          Great work!
                            This is amazing! Thank you to you and everyone else who tested it. Hopefully in the future versions there will be the options to program and change small things in the tune like in martins tool.
                              Amazing. Looking forward to playing with this when I'm back in town.
