I know all the normal manufacturers (CMP, Vincebar, Mason, etc.) of these top mount reinforcement bars do not make a version compatible with convertibles. Has anyone cobbled together something to accomplish the same result they can share or is this something you just get a welder to fabricate when doing subframe reinforcements?
Convertible top mount subframe bar?
I have been looking for one for a while but I haven't found anyone that makes one. I did have my trunk completely pulled apart just recently and it looks like it is possible since the top mounts have some clearance...not much though. The bracket would have to go down first instead of just straight across like a coupe to clear the area where the soft top goes.2002 M3 LSB/Kiwi Vert
2014 X5 50i
2019 Ford Raptor
Yeah, the strut tower bars would be difficult. I was hoping something across the floor though for subframe reinforcement. I imagine a welder could fabricate something with a boxed section and plates á la vincebar style but I don't know.
Sidebar: LSB and Kiwi sounds wild, I bet you get some looks with that combo. LSB/Cinnamon here
Probably about 2 years ago now, I was chatting with Vince about the compatability of his bar with convertibles. I can't remember the details, but my impression was that it is installable, just not entirely. But mostly? Something about front gussett cups.
I think it's worth reaching out to Vince directly and asking him about it. He was very helpful and I think was basically saying it's no problem to install his bar on a convertible, it just won't provide *all* of the reinforcement it would on a coupe. Things/design may have changed since then, though.Last edited by ATB88; 06-19-2020, 02:15 PM.
From what ive found the Vincebar set up will work on the rear 2 mounts but the gusset caps wont work on the fronts. You could definitely do just the rear part. I was reading on the last forum since someone was selling a vincebar set for a good price and he was supposed to be working on something for the convertible front mounts but nothing yet.Originally posted by ATB88 View PostProbably about 2 years ago now, I was chatting with Vince about the compatability of his bar with convertibles. I can't remember the details, but my impression was that it is installable, just not entirely. But mostly? Something about front gussett cups.
macaroni86 - I really like LSB/Cinnamon and was going to do that but found a Kiwi interior in Canada close to me so I thought id give it a shot. Definitely different. Probably not another one like it. Im just finishing up a re-dye and refresh of my interior and was planning on posting up some pics when im done.
2014 X5 50i
2019 Ford Raptor
You should!Originally posted by dilmorecg View PostIm just finishing up a re-dye and refresh of my interior and was planning on posting up some pics when im done.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - SSV1 - HJS - Mullet Tune - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
Yes, I believe this is correct.
CMP advised me that the convertibles don't need a front reinforcement bar due to the fixed rear seats (but you can still get popped gusset welds there). I had a DIY stealth bar made up out of 1" box section steel. This size required an extension strip to be added to the floor panel cutout so it could be welded back on (but that's probably unavoidable anyway). I had the cutout re-welded and boot floor repainted by a body shop - looked OEM when done. Noticeably stiffened up the backend (had poly subframe mount bushes put in too)
The stealth bar combined with a good front strut brace really stiffens up the 'vert nicely.
The CMP is an H bar config adds another directly between the chassis rails - but this intrudes into the boot
From what I learned this kind of bar is essential to stop cracking. Putting reinforcement plates on the underside to repair cracks is treating the symptom not the cause. The bar directly couples the rear mounts to the chassis rails, thereby solving the chassis design flaw that relies solely on sheet metal to do the job (which flexes and eventually fails due to fatigue)
I read on m3cutter apparently this bar will work with verts. https://www.s-m-eng.com/product-page/e46-racp-brace
I’m told that the rear subframe issue isn’t really a problem on convertibles, as the chassis is already beefed up to handle the lack of a top... this from a source who’s way more knowledgeable and into these BMW M cars than I ever will be... are there any confirmed vert owners with rear subframe issues? that might feed into why you can’t find reinforcement bars for convertibles.
maw
For the last few posts on verts being beefier and not needing a reinforcement, article 2 from CMP outlines the different failure modes, which includes verts.
Youtube DIYs and more
I have a vert - bought second-hand from a BMW dealer with only 67,000 Kms (well under 50,000 miles) on the clock last year. It had cracking around left rear sub-frame mount. Threatened to sue them, got partial refund and put in custom 'stealth bar' solution' (see my previous post on this thread).Originally posted by maw1124 View PostI’m told that the rear subframe issue isn’t really a problem on convertibles, as the chassis is already beefed up to handle the lack of a top... this from a source who’s way more knowledgeable and into these BMW M cars than I ever will be... are there any confirmed vert owners with rear subframe issues? that might feed into why you can’t find reinforcement bars for convertibles.
maw
As CMP says, all E46s will eventually fail (except for the compact)
Does anyone here have experience with this? I have been looking for a solution for a while. I had the RACP reinforcement done this year, and would like to beef up the bracing. And yes, convertibles ARE subject to cracking.Originally posted by Egone View PostI read on m3cutter apparently this bar will work with verts. https://www.s-m-eng.com/product-page/e46-racp-brace
I just got mine today. Amazing fit. Trying to talk a friend into installing one on his vert since it's one of the few options that fit:Originally posted by Andrew 06M3Cab View Post
