DIY: CSL Trunk Install
    Originally posted by Titaniu//M View Post
    Install the grommets for the trunk roundel and pop in the blind rivets for the plate bracket. I tore one, and am waiting for a replacement to come in. Do not order the OE screws for the plate bracket (51248223104). They are too short. I will have to run to the hardware store to finish off my install with longer bolts.
    How did you get the blind rivets installed? I removed the washer then tried to push them through from the back with no luck.
      They just pop in to the two holes from the same side the license plate mounts on (not sure if that's what you mean by the "back"). Takes a bit of finesse as you need to pinch the end a bit. I found it helpful to mount the blind rivet on the end of a dowel, and push them in that way but the blind rivets are also easy to tear.
        Great write up!
          May I ask what tabs you dremeled I’m installing mine and cant get the lights to seat properly.
            I do not remember exactly the spot I had to file down but if you look at lights and how they fit in you should be able to get it figured out. I do remember removing a small portion of the foam rubber weather stripping on the lights and hand filing the light in the same spot so I could them to pop in.
              For those that installed the "M3 emblem", where did you feel like the emblem should go? I know it's subjective because the csl emblem is longer, but I'm trying to figure out where to tell the paint shop to install it. Included pictures for reference...
              Garage:
              2002 BMW M3: Slicktop jetblack/cinnamon. SMG to 6-speed. Arc-8's. Koni yellows/Dinan springs. Macht elbow. Megan headers. Stock section 1+AR20. SCZA section 3.
              2001 BMW 740i
                A good, balanced spot to place it is lined up with the top left side of the reverse light and the bottom of the BMW badge. It seems like they would have done this from the factory.
Name:	csl badge 1.jpg
Name:	csl badge 2.jpg
                  saw this post about badge alignment measurement. FYI
                    Reviving this thread. Does anyone have the trunk open indicator light on the cluster after installing their CSL trunk, since there’s no button release under the handle anymore?
                    996TT
                    Turbo E36 M3
                    FZJ80
                      I don't have any trunk open indicator light on the cluster.
                      2004 M3-Silver Grey Metallic/Imola Red-Coupe-6spd
                      2002 330Ci-Topaz Blue Metallic/Black-5spd
                      Instagram- Norocehcap
                        Sorry for just finding this post but quick question - where did you find the CSL trunk liner. I'm being told the OEKM trunk liner will fit the CSL trunk lid. Not correct?
                          What brand is your CSL trunk?
                            Reviving again. I just installed my VIS CSL-style trunk and I've got the light on the dash continuously. Deen HK, did you ever figure yours out?
                              This DIY was super helpful, thanks Titaniu//M for the thread. Just wanted to add or mention for others that pin2 is going to be your + and pin3 is going to be your - when you're connecting to the 3 pol terminal. I just had to flip my pins since for some reason I had it reversed. Thanks again.
                              /// 2004 SG/IR - Build Thread
