Fixable?
    Originally posted by oldFanatic View Post
    Sorry to see your car got damaged.
    Without seeing under the hood damage and seeing the fender/door/windshield alignments it's hard to say how bad it will be for you or costly for a shop to repair.
    Just tore out the front end a bit today, I see no damage from the bumper support, only the left side of the radiator support & fans including exterior parts ( hood, headlight & etc ).
      Anyone got a good recommendation on cooling system? Other than oem. Mind as well upgrade parts.
        That side skirt concerns me a bit. Did it come loose in the accident? If so, how? I would personally measure (or have a frame shop measure) everything to be absolutely sure that there is no frame damage.
          The side skirt was already like that. It was already ripped off from being too low & going thru ugly speed bumps lol & I’ll look into that more
