Originally posted by T.J.
View Post
I ignored the tps light and got a blowout!
This isn't what the post he quoted was referring to:Originally posted by Dash1 View Post
Actually they do. The TPMS uses the wheel speed sensors to differentiate individual tire pressures through their rpm’s.
The RF sensors started with the E9X cars. Luckily you can run without them and code the cars back to the same FTM system the E46 uses.There are little hand held scanners that test TPMS Sensors. Use that instead of wasting money. You may have damaged the sensor during the blowout but the tire isn't shreaded so you may be in luck. It takes about 3 minutes to test all 4 sensors. They send out a specific frequency to a reciever in your car. It's typically 433Mhz sent out. Each one must be programmed to the car. Receivers can typically recieve other frequencies but if a different frequency is used for one sensor, that may cause a problem, confusing the module.'03.5 M3 SMG Coupe - Jet Black / Black
It doesn’t matter. You guys are caught up on semantics for the sake of getting brownie points. If you really see an error, go ahead and call him/her/them out and have the proper answer. Otherwise, you’re just adding to the confusion.Originally posted by r4dr View Post
There is no proper answer to that error, because there are no RF sensors in the wheels therefore there is no handheld receiver that you can use to read and/or test TPM sensors that do not exist. If the wheel speed sensors in these cars are off my understanding is that it will set off errors in the ABS as well. I think it's important for someone who comes across this thread to not be confused that there are modern-style radio frequency sensors in their car that do not exist, but maybe that's just me.Originally posted by Dash1 View Post
It doesn’t matter. You guys are caught up on semantics for the sake of getting brownie points. If you really see an error, go ahead and call him/her/them out and have the proper answer. Otherwise, you’re just adding to the confusion.'03.5 M3 SMG Coupe - Jet Black / Black
From the manual:
So it's not that the wheel speed sensors have something special that can tell tire pressure, but rather that they're used to deduce if a tire is low. If the rpms reported by the wheel speed sensors are different (by enough), then a tire is probably low.As you drive, the Flat Tire Monitor
keeps track of pressure levels in all four
tires. The system alerts you whenever
the inflation pressure of a tire falls sig-
nificantly below the pressure of another
tire.
Controlling the tire pressure is based
on monitoring the rpm that the tires
have relative to each other. A flat tire is
detected and reported because the rpm
suddenly deviate drastically from one
another.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - SSV1 - HJS - Mullet Tune - MK60 Swap - E86 Front Triangulation - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
Cool. So the tire pressure is derived from the relative rotation rates of the wheels. Hence the wheel speed sensors... ThanksOriginally posted by heinzboehmer View PostFrom the manual:
Yup exactly.Originally posted by yhp2009 View Post
Cool. So the tire pressure is derived from the relative rotation rates of the wheels. Hence the wheel speed sensors... Thanks2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - SSV1 - HJS - Mullet Tune - MK60 Swap - E86 Front Triangulation - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
Thanks for the feedback everyone! Couple of notes, although the tires are not the most expensive brand, they are not expired by any means, and plenty of life left so i didnt see a reason to change them. The reviews for the gmax rs were good. I dont track the car so it doesnt see much wheel spin or drifting.
The car is in the shop now getting michelin pilot 4s tires.
they also said the rest of the tires dont need changing, but im doing all four anyway 🙂
Good thing you're changing all 4. Mixing tire compounds is a VERY bad idea.Originally posted by Mc645 View PostThanks for the feedback everyone! Couple of notes, although the tires are not the most expensive brand, they are not expired by any means, and plenty of life left so i didnt see a reason to change them. The reviews for the gmax rs were good. I dont track the car so it doesnt see much wheel spin or drifting.
