List Your Suspension/Wheels/Tires Setup in Great Detail
    If you have them handy be sure to post your alignment specs.
    How/Where I Drive: spirited driving on the streets
    Ground Control Street Coilovers (koni/eibach)
    Front:
    Apex ARC-8 19x9 et 28
    Michelin A/S 3+ at 245/35/19
    Camber: 2.0 degrees
    Rubs: No
    Spacers: None
    Springs: 6" 500 lbs Eibach (I wish I had known about flat ride, will adjust at some point)
    Camber Plates: Ground Control
    Ride Height: 13.35 inches (from center of wheel to fender arch)
    End Links: Ground Control
    Control Arm: OE
    Sway Bar: OE
    Tie Rods: OE
    FCAB: OE
    Brakes: OE
    Rear:
    Apex ARC-8 19X10 et 25
    Michelin A/S 3+ 275/30/19
    Camber: 1.8 degrees
    Rubs: No
    Spacers: None
    Springs: 6" 600 lbs Eibach
    Ride Height: 13.25 inches (from center of wheel to quarter panel arch)
    End Links: OE
    Ball Joints: OE
    Bushings (except RTAB): OE
    Sway Bar: OE
    ARCAs: Ground Control Monoball
    RTABS: CMP Monoball
    Subframe: CMP Solid
    Brakes: OE
    Add a picture if you can!
    I am already loving this POST!!!
    Currently stock, and looking for more info and guidance.
    I do have KONIS & Dinan springs in the garage ready to go on
    I will follow up with all my deets when I get them on.
    Thank you.
      Front:
      Apex ARC-8 18x9.5 et35
      Michelin PS4S 265/35/35
      Camber: 2.7 degrees
      Rubs: No
      Spacers: 3mm(to clear Porsche brakes)
      Springs: 7" 350lbs front springs
      Camber Plates: Vorshlag
      Ride Height: 13.5 inches (from center of wheel to quarter panel arch)
      End Links: Turner Motorsport adjustable
      Control Arm: OE
      Sway Bar: Hotchkis
      Tie Rods: OE
      FCAB: Turner Motorsport monoballs
      Brakes: Porsche Brembo
      Rear:
      Apex ARC-8 18x9.5 et22
      Camber: 1.8 degrees
      Rubs: No
      Spacers: None
      Springs: 5.5" 650lbs rear springs
      Ride Height: 13 inches (from center of wheel to quarter panel arch)
      End Links: OE
      Ball Joints: OE
      Sway Bar: OE
      ARCAs: OE
      RTABS: Syncro Design Works
        How/Where I Drive: Spirited Street / Track
        This setup will turn laps all day, very neutral feel and no fade from the brakes.
        Ground Control Race Coilovers (koni/eibach)
        Front:
        Michelin Pilot Sport Cup 2 - 265/35r18
        Camber: 3.0 degrees
        Rubs: No
        Spacers: 5mm
        Springs: 6" 450 lbs Eibach
        End Links: OE (on my list to switch to adjustable end links this winter)
        Control Arm: OE
        Sway Bar: OE
        Tie Rods: OE
        FCAB: Turner Monoball
        Brakes: 355MM Brembo BBK
        Rear:
        Camber: 2.0 degrees
        Rubs: No
        Spacers: 12.5mm
        Springs: 6" 550 lbs Eibach
        End Links: OE
        Ball Joints: OE
        Sway Bar: OE
        ARCAs: Turner
        RTABS: Garagistic Poly (swapping to OE+ limiters or SDW Monoball soon)
        Brakes: OE + Brass guides + ss lines
          Street/Cyn
          Front:
          OE CSL 19" x 8.5 et44
          Michelin PS4S 235
          Camber: -3 degrees
          Rubs: No
          Spacers: 15mm
          Dampers: Bilstein B6 w/ GC 2.5" perches & cut off 7/8" of bump stop
          Springs: 7" 325lbs 2.5" Eibach ERS
          Camber Plates: TMS street - gives me extra 7/8" of travel
          DMG strutbar
          Ride Height: 13.375 inches (from center of wheel to fender arch)
          End Links: OE
          Control Arm: OE
          Sway Bar: Hotchkis (Med)
          Tie Rods: OE
          FCAB: OE
          Brakes: Porsche Brembo 996, Textar pads
          Rear:
          OE CSL 19 x 9.5 et27
          Michelin PS4S 265
          Camber: -2.5 degrees
          Rubs: No
          Spacers: 5mm
          Dampers: Bilstein B6 w/ GC shortened bumpstops & GC "tall" RSMs - raises droop more than an inch
          Springs: 6.5" 550lbs GC Eibachs, GC top cones, oe rubber bottom pads
          Ride Height: 12.875 inches (from center of wheel to quarter panel arch)
          End Links: OE
          Ball Joints: OE
          Sway Bar: OE
          Added rear strut bar
          ARCAs: Eibach aluminum
          Brakes: Porsche Brembo 996, ATE pads/fluid
          Toe out up front, toe in rear
          Pics:
ID:	97075 Click image for larger version
ID:	97074 Click image for larger version
ID:	97070 Click image for larger version
            Driving spans baby hauling to track days
            Front:
            ARC8 18x9.5 et35
            Michelin PS4S 265
            Camber: -2.8 degrees
            Rubs: No
            Spacers: used to run Apex 3mm when had worn wheel bearings to clear tire to Ohlins strut clearance
            Dampers: Ohlins DFV, Ohlins bottom spacer (3dmmotorsport)
            Springs: 7" 375lbs Hyperco
            Camber Plates: GC street, OE strut tower reinforcement plate
            Stock front strut bar
            End Links: OE
            Control Arm: OE
            Sway Bar: TMS (Soft)
            Tie Rods: OE
            FCAB: OE
            Brakes: ST40 355x32, PFC08 pads, RBF600 fluid
            0 toe
            ZHP steering rack
            Apex 75mm stud conversion
            Rear:
            ARC8 18x9.5 et35
            Michelin PS4S 265
            Camber: -1.8 degrees
            Rubs: No
            Spacers: Apex 12mm
            Dampers: Ohlins DFV, Garagistic shock tower mount reinforcement plate
            RSM: GC street
            Springs: 5" 672lbs Swift, Rogue Engineering upper control arm reinforcement plate
            End Links: OE
            Ball Joints: OE
            Sway Bar: OE
            ARCAs: stock salad tongs, eccentric bolt maxed out for camber
            RTABS: Rogue Engineering
            Brakes: stock calipers/rotors, PFC08 pads, RBF600 fluid, brass bushings
            1/8 total toe in
            CMP topside beam with front extension welded in (no shock tower bar)
            Car in pic loaded for a road trip, so sits a bit lower.
            Youtube DIYs and more
              This thread would benefit with accompanying each post with photos too
              Current:
                How/Where I Drive: Spirited street/ track
                JRZ RS2 Non-remote
                Front:
                Yokohama A052 265
                Camber: 2.6
                Rubs: No
                Spacers: None
                Springs: 6" 650 Hyperco
                Camber Plates: Ground Control Street
                Ride Height: 13.5
                End Links: Ground Control adjustable
                Control Arm: OE
                Sway Bar: OE
                Tie Rods: OE
                FCAB: OE
                Brakes: OE
                RBF 600 fluid, stoptech pads
                Rear:
                Yokohama A052 265
                Camber: 1.9 degrees
                Rubs: No
                Spacers: Apex 12mm
                Springs: 5" 750 Hyperco
                Ride Height: 13
                End Links: OE
                Ball Joints: OE
                Bushings (except RTAB): Turner solid
                Sway Bar: OE
                ARCAs: OE
                RTABS: Turner
                Brakes: OE
                  Front:
                  ARC8 18x9.5 et35
                  Michelin PS4S 265
                  Rubs: No
                  End Links: OE
                  Control Arm: OE
                  Tie Rods: OE
                  FCAB: OE
                  0 toe
                  ZHP steering rack
                  Rear:
                  ARC8 18x9.5 et35
                  Michelin PS4S 265
                  Rubs: No
                  Spacers: Apex 12mm
                  RSM: GC street
                  End Links: OE
                  Ball Joints: OE
                  Sway Bar: OE
                  1/8 total toe in
                  Curious why you're running OE front strut tower reinforcement plates with the GC camber plates, since they already come with their own reinforcement plates?
                    I will try to get a screenshot from the video I took while doing the Ohlins 3dmmotorsport spacer install, the surface area of GC camber plates is tiny. Unless yours came with something mine did not, I'd recommend using the reinforcement plates.
                      How/Where I Drive: 80% Track 20% Street
                      Öhlins Dedicated Track Coilover Kit
                      Corner Balance and Alignment by Chewerks
                      Front:
                      Bridgestone Potenza RE-71R 265/35/35
                      Camber: -3.7 degrees
                      Rubs: No
                      Spacers: None
                      Springs: Swift - Öhlins Spec 700#
                      Camber Plates: Öhlins w/ spherical bushings
                      Control Arm: OEM
                      Sway Bar: OEM
                      Tie Rods: OEM
                      FCAB: Bimmerworld Race
                      Brakes: OEM ZCP w/ Endless ME20 race pads, Endless RF650 fluid
                      Rear:
                      Camber: -2.7 degrees
                      Rubs: No
                      Spacers: None
                      Springs: Swift - Öhlins Spec 900#
                      RSM: Öhlins w/ spherical bushings
                      End Links: OEM
                      Ball Joints: OEM
                      Bushings (except RTAB): Powerflex Black
                      Sway Bar: OEM
                      ARCAs: Bimmerworld
                      RTABS: Powerflex Black
                      Current: 2003.5 E46 ///M3 6MT - 2019 Ford Raptor 802A
                      Past: 2015 F80 ///M3 6MT - 2006 E46 ///M3 6MT - 1999 E36 ///M3 5MT - 1991 E30 ///M3 5MT
                        Front:
                        Forgeline ZX3R 17x10 ET38
                        Nitto NT05 275/40/17
                        Camber: -3.5 degrees
                        Rubs: Nope
                        Spacers: 15mm (to clear Brembo GTRs)
                        Springs: 7" 500lbs Hyperco
                        End Links: OE
                        Control Arm: OE
                        Sway Bar: H&R (set to medium)
                        Tie Rods: OE
                        FCAB: OE
                        Brakes: Brembo GTR 4 piston calipers, 355mm Brembo Type V rotors, Raybestos ST43 pads, Motul RBF660 fluid, Goodridge lines
                        Rear:
                        Rubs: Nope
                        Spacers: 12.5mm (for looks really)
                        Springs: 5.5" 550lbs Hyperco
                        End Links: OE
                        Ball Joints: OE
                        Bushings (except RTAB): AKG 90s
                        Sway Bar: OE CSL
                        ARCAs: OE
                        RTABS: RE Track
                        Brakes: Centric blanks, Raybestos ST43 pads, Motul RBF660 fluid, stock lines
                        TCK DA suspension, custom alignment/corner balance done at Fast Track Motorsports in Peabody, MA.
                        ZCP steering rack.
                        Macht Schnell 90mm stud kit.
                        Oh 0 toe all around.
                        Someone asked for pics, okie.
Name:	M3 JP Licks.jpg
                        2005 BMW ///M3
                        Black6MT Daily
                          How do you like ME20 and what have you run before them? I am swapping them (I think they rebranded as CC40) into my S2K after baking EBC red in the canyons. Don't see too many BMW guys with them as Endless seem to be more prominent in JDM scene.
                            Let you know after this weekend, just installed them today. Previously I’ve run Hawk DTC-70/60, PF01, Carbotech XP12/10, Project Mu CR, CL RC6, and a bunch of others, but all on different cars.
                              How/Where I Drive: daily driver. mostly highways and around town with occasional mountain cruises
                              JRZ RS1 single adjustable
                              Front:
                              Volk Racing G2 18x9.5 +35
                              Continental ExtremeContact Sport 265/35-18
                              Camber: 2.5 degrees
                              Rubs: No
                              Spacers: 5mm
                              Springs: 6" 450 lbs Hyperco + Hyperco helper Spring
                              Ride Height: 13.5 inches (from center of wheel to fender arch) (need to reconfirm this)
                              Control Arm: OE
                              Sway Bar: OE
                              Tie Rods: OE
                              FCAB: OE
                              Brakes: OE (StopTech BBK soon)
                              Steering rack: Z3 linear rack
                              Rear:
                              Camber: 1.8 degrees
                              Rubs: No
                              Spacers: 12mm
                              Springs: 5" 550 lbs Hyperco + Hyperco helper spring
                              Ride Height: 13.25 inches (from center of wheel to quarter panel arch) (need to reconfirm this)
                              End Links: OE
                              Ball Joints: OE
                              Bushings (except RTAB): Turner Motorsport spherical upper inner
                              Sway Bar: OE
                              ARCAs: Turner Motorsport Street
                              Brakes: OE
                              pardon the peeling clearcoat 😥
                              2007 GX470
                              build/journal
                              ig: @zzyzx85
