Originally posted by dukeofchen
Difficulty Getting Into Gear at Speed
No. Brake the car to hold it on a slope surface, then engage 1st or R gear. Release clutch pedal up (clutch fully engaged). Release brake and car is held by the engaged gear and clutch. slowly push down clutch pedal until car starts to roll down hill. This is the clutch releasing position and make note of the pedal position relative to its bottom position (stopped by the floor stopper). There should be at least 0.5 to 1" free travel from "start release" to stopper.'04 LSB Coupe 6MT
"There should be at least 0.5 to 1" free travel from "start release" to stopper."
I should have said clearance should be between 0.5 to 1" and not more than this. IF pedal has more than 1" free travel after release point, the PP plate diaphragm could be over extended if pedal was pushed down to stopper, causing the PP to reverse and touch the clutch disc instead of total release.
While putting things back together tonight I must not have seated the slave cylinder properly while reinstalling and it burst when I went to start the car.
Looks like regardless of the diagnosis the tranny is definitely coming out now, because the rest of the parts are inside of the bellhousing 😂
When life gives you lemons...
'04 LSB Coupe 6MT
Originally posted by dukeofchen View PostWhile putting things back together tonight I must not have seated the slave cylinder properly while reinstalling and it burst when I went to start the car.
I think with a magnet and times you can fish out the pieces and no need to drop the tranny.
Originally posted by sapote View PostI think with a magnet and times you can fish out the pieces and no need to drop the tranny.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - SSV1 - HJS - Mullet Tune - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
Originally posted by jbfrancis3 View PostI think he needs to get there to inspect things based on his original post
If I can get it properly bled I'll attempt the clutch drag test, but at this point all signs still seem to be pointing towards dropping the trans and scoping things out.'04 LSB Coupe 6MT
Holy hell I have to say getting the transmission off on jack stands is no joke. Particularly when one of the E14 bolts had been mangled by whoever last touched it and was impossible to get seated in the socket (after an embarrassing amount of time wasted we took the risk and broke it free with an E16 socket).
First finding and possibly the root of the problem: the nylon clutch pivot pin had completely sheared, so it seems the clutch fork was likely out of position. If that was the case then it makes sense why the full pedal throw w/o a clutch stop was not translating into the distance required to fully release the clutch. Would also explain why I was having these issues without any kind of slip or noises that would accompany failure of the other components.
The inside of the bell housing is absolutely filthy, so rear main seal is definitely getting done. Even though it seems like this was due to the pin my inclination is to replace the RMS, clutch / PP, TOB, fork, retainer spring and pilot bearing along with throwing in the stainless pin. Will take a look at the flywheel but honestly I'd rather not do this again so regardless of condition I might replace that too.
Originally posted by FBloggs View PostDid you replace the plastic pivot pin for the clutch fork?Last edited by dukeofchen; 08-09-2021, 10:04 AM.'04 LSB Coupe 6MT
Originally posted by dukeofchen View PostFirst finding and possibly the root of the problem: the nylon clutch pivot pin had completely sheared
As about using a SS pin, since the fork is metal and so metal pin to metal fork will wear out faster than plastic pin or brass. Make sure to add some moly grease to the pin tip/fork dimple cave.
I've been dealing with an on/off (more on that off) again issue with the 4=>3 downshift in the race car at high speeds with the ZF 5-speed. Bled slave, already had stainless steel pivot pin, checked tranny mounts, etc. and have come to the conclusion it's time for a different route.
I've ordered a 5-speed dog box from GearMotive (https://gearmotive.com/en/product/bm...-speed-dogbox/) which should be the end of the issue. 🤞
Feff
