Eml light
    How will I look at the PIDs?
      Originally posted by M3powerzz View Post
      Now I have a new problem . idle surge, and the car stalls when coming to a stop. If the rpm is above 2k, and I put the car in neutral, rpm drops and stalls. I have to tap the gas a bit to prevent it from stalling. Only happens when coming to a stop. If the car is in neutral and I rev. Its fine, no stalling.
      After you changed the TPS did you reset the throttle adaptations?
        I followed instructions how to do it.. Key on for 10 seconds, then key off for 10 seconds, then key on for another 10. Then start car.. Is that correct?
          I found a video and it says. Foot on the gas all the way down. Put key in ignition and turn to position 2. Count 10 seconds. Turn car off and release gas pedal. That should reset the adaptation.. And I drove the car and the stalling stopped. It fixed it. Tomorrow im going for a longer drive and check.
            I've only reset the throttle adaptations using INPA so imI can't really comment on other methods.
            After successfully resetting the throttle adaptations the first start afterward is usually very rough idle hunting until it settles down.
              Well I guess it's fixed then ​​​​​
              You can use INPA to see info. Do you have it?
                Yeah I have inpa , but I get a error message when open it.
                  Update , the problem is still happening. Stalling when coming to a stop.
                    Im going to change the clutch switch next.. 61319122700
                    thats the correct part #?
                      My advice would be to get INPA working first instead of throwing parts at it.
                        Yeah I will try to get it working. The stalling problem happen after I used the cruise control. iirc
                          Thanks everyone for the help. I figured out what was wrong causing the stalling. The tube that goes into the intake manifold next to the dipstick wasn't in all the way.. Now the car is running good.
                            Hey All i have a EML light and car stalls when coming to a stop, all TPS are brand new and throttle pedal too, No obstructions to TB linkage etc. car is SMG. Any tips? Thanks
                              I believe Obioban posed q question regarding the id (code wise) of the respective tps in the last month or so.
                              If the car tosses another eml at you, I think the post will come up on a search.
                                Will have a look right now. All TPS sensors including Throttle Pedal are new.
