How will I look at the PIDs?
Eml light
After you changed the TPS did you reset the throttle adaptations?Originally posted by M3powerzz View PostNow I have a new problem . idle surge, and the car stalls when coming to a stop. If the rpm is above 2k, and I put the car in neutral, rpm drops and stalls. I have to tap the gas a bit to prevent it from stalling. Only happens when coming to a stop. If the car is in neutral and I rev. Its fine, no stalling.
I found a video and it says. Foot on the gas all the way down. Put key in ignition and turn to position 2. Count 10 seconds. Turn car off and release gas pedal. That should reset the adaptation.. And I drove the car and the stalling stopped. It fixed it. Tomorrow im going for a longer drive and check.
Well I guess it's fixed then ​​​​​Originally posted by M3powerzz View PostHow will I look at the PIDs?
You can use INPA to see info. Do you have it?This is my Unbuild Journal and why we need an oil thread
Will have a look right now. All TPS sensors including Throttle Pedal are new.Originally posted by FBloggs View PostI believe Obioban posed q question regarding the id (code wise) of the respective tps in the last month or so.
If the car tosses another eml at you, I think the post will come up on a search.
.. Now the car is running good.
