Everything about Fat Cat Motorsport Suspension
    It's been a while since I've been on forums and have been through a few different spring setups since this original post. I think I have finally found an OEM+ street setup that is comfortable and sporty. Through trial and error and I tested many different setups. Below is a brief overview of that journey...
    1) 350/336 F (7" linear springs) & 700/675 R (5" linear springs) -- TMS Front (medium setting) & Rear (soft setting) Sway Bars --> bad oscillations over bumps and the car would not settle. I believe this was because of the linear springs in the rear. Per the Ride Harmony spreadsheet, 1.07 "flat ride", 73.8% FRC.
    2) 350/336 F (7" linear springs) & 500 R (TCK barrel springs) -- TMS Front (medium setting) & OEM Rear Sway Bars --> oscillations from previous setup were gone. Per the Ride Harmony spreadsheet, 0.92 "pitched", 77.8% FRC.
    3) 400 F (Eibach 170-60-0070, 6.69" linear spring) & 600 R (TCK barrel spring) -- TMS Front (medium setting) & OEM Rear Sway Bars --> Very stiff ride. Per the Ride Harmony spreadsheet, 0.93 "pitched", 74.4% FRC.
    4) 336 F (Swift Z60-178-060, 7" linear spring) & 600 R (TCK barrel spring) -- TMS Front (medium setting) & OEM Rear Sway Bars --> Very sporty on the street, while maintaining comfort on rough roads. Per the Ride Harmony spreadsheet, 1.02 "flat ride", 75.6% FRC.
    For the latest setup, I still need more seat time. Initially impressions were great and I am really enjoying this setup so far. Personally, 600# rears are as stiff as I'd like to go, to maintain my comfort level. If I want to aim towards an OE level "flat ride" it would require making the front springs much softer. The stock suspension has a 1.18 "flat ride" ratio, which would require 250# fronts and 600# rears. I might try that in the future, but for now I'm happy.
    2005 BMW M3 ZCP Black/Black - HTE Tuning | Kassel CSL DME | 288/280 Schrick Cams+DLC Followers | Lang Head | Dinan TBs | Bosch 550cc | Radium Fuel System | Karbonious CSL Airbox+OE Snorkel | SS V1 Stepped+Catted Sec 1+Resonated Twin Pipe+Race | 3.91, 3 stage clutch | FCM 400/600 | Vorshlag Camber Plates, RSM | Rogue ASP | AKG FCABs, SFBs | TMS Front Sway, Camber Arms, Monoball RTABs, Pullies | Mason Race Strut + X-Brace | AS 30% SSK | SPAL | Redish Plates | Turbo Toys V2 Hub | WPC Rod Bearings
      I'm writing this more for me to remember things but I also want to document my journey on deciding what direction I want to go.
      My suspension is getting worn out. I can feel the suspension bottom out, especially when I messed up and ran over a sausage curb at COTA. It was kind of brutal and alarming...never really had that before. And I've definitely ran over those curbs before. My dampers are almost 13 years old and have seen over 50k miles across 2 cars. I have zero doubt its time.
      Right now, I have TC Kline doubles with 500/700lb springs, stock front bar, no rear bar. Ride heights are (bottom of fender to ground) 26" in the front and 25.25 and 25.375 in the rear. Weight as "raced" is 2866 (LF 791, RF 691, LR 728, and RR 655).
      I've talked to Cronenberged and messaged thegenius46m to get there experience with FCM. Both were a tremendous help...thanks!
      Here's the dilemna. I'm mostly happy with the TCKs. My car is far more comfortable than almost every street car that I instruct in. The results of kind of applying flat ride have been great. Won NASA TT3 despite being closer to a TT4 car. I run consistent 1:41s at MSR Houston on RRs and NT01s, not many cars under 400whp are running those times on those tires. I'd be well in the 1:39s with a Hoosier.
      My only complaint is low speed understeer - under 60 mph. It turns in but it feels rather dull. Trail braking deeper has helped (also helps with lap times) but over time I have learned to drive around it. This doesn't really hurt me that much at MSR Houston (my home track - bumpy), I think this understeer has a significant impact at the tracks in Fort Worth which have a newer and smoother surface. I'm not nearly as competitive on those smooth tracks.
      I am also very skeptical of vendors. I've heard a lot of bullshit from some of the more popular vendors. FCM seems different in a good way. Maybe a little eccentric? But to be better you have to be a little different. If do go FCM, no doubt it will be the Stage 3 Elite. I guess it comes out to $5500-ish all said and done. Its about $1000 more than MCS and $3000 more than replacing my TCK dampers. If I can get the suspension right out of the box then $5500-ish sounds cheap when you factor in the time and expense to get the suspension dialed in.
      It will be a couple of months. I want to get most of the weight reduction done before I do the consult. I hope to make a decision this fall and post here which direction I go and why.
      Why do you need to replace the TCK? A rebuild job at PSI where TCK sends them is $1200. That's $4300 less than FCM.
      Instagram: @logicalconclusion
        I think it’s closer to $1500 but replacement TCK Koni’s is around $2200.
        Don’t need to go away from TCK. Might be possible to get more lap time with FCM, no guarantee of course. Maybe I accidentally optimized everything.
        The challenge here is I really need to think about what I want before doing the consult with FCM. I think I’ll know more after the consult.
          Based on your experience, you probably need the best dampers you can afford. I'm not sure if the TCK DAs match some of the higher end monotube dampers. What about a true coilover rear?
            I think it's closer to $1500 but replacement TCK Koni's is around $2200.
            Don't need to go away from TCK. Might be possible to get more lap time with FCM, no guarantee of course. Maybe I accidentally optimized everything.
            The challenge here is I really need to think about what I want before doing the consult with FCM. I think I'll know more after the consult.
            Do you care about adjustability of the dampers? If the answer is yes, then FCM might not be the best option for you since they rebuild no -adjustable H&R street dampers. You are also locked into FCM for service, who is a small business and who knows how long he will be around.
            From a cost perspective, other high end adjustable dampers will likely give you the same performance, but it will take more effort to get them tuned in. You also get warranty and service from a larger business. (For better or worse.)
              Lack of adjustability is a positive or a negative depending on your point of view. The upside is that you can’t screw it up. The downside is that if you change your spring rates or meaningfully change the weight of your car, you do need to get the revalved.
              I kind of love the freedom of no adjustability. So much less to be screwing with at track events—just worrying about camber and tire pressures is remarkably freeing.
              Not sure I agree you’re getting the same thing with other high end dampers. FCM has a pretty different philosophy than any other suspension tuner I know of (minimize rebound, minimize shock pressure, flat ride). If that’s what you want, he’s a bit the only game in town.
              Rebuilds of FCM modified shocks can be done by any Bilstein rebuilder. Valve changing… yes, you’re stuck with them. Would be problematic if they went away. That said… TC Kline looks to be WAY closer to retirement than Shaikh.
                It's $1200 as far as I know, $300/corner.
                  There's more left to cut? Short of drilling holes in structures and swapping to titamium hardware?
                  Youtube DIYs and more
                    Lol…The goal is sub 2500lbs - about 2475 so I can install a cage with .095 wall tubing which should cut another 60lbs. Would be awesome if I could get to 2400lbs but that will be really tricky.
                    I have done almost all of the deleting and removal - just the secondary oil cooler remains. Need to figure that out. I’m at the point where I need to spend money and make things in a lighter material.
                    I don’t see a way to get to my goal without making the weight distribution a little worse. So one question I will have for FCM is how much of an impact will 1%-2% change in distribution have on how the dampers will be built before re-corner balancing?
                    or…what is the cost to re-optimize? I don’t mind spending the $5k up front and a little more as needed with car changes. Don’t want to spend $5k and another $5k. Rather just rebuild the TCKs for now and go FCM when the car is at the target weight.
                    If it weren’t African hot here in TX…I could make some good progress.
                      Suspension Decoder read last few pages.
                        At this point it practically IS a guarantee to go faster when switching to FCM. People show up with TCK, Ohlins, MCS, JRZ, Moton, whatever and always go faster with an FCM Elite Bilstein-based setup.
                        The TC Kline front and rear have a fair amount of low speed jerk in bump which isn't good for tire grip or lap times (or comfort - amazing how those three are connected...!).
                        The TC Kline front rebound is less aggressive than OE which is better for overall grip and compliance but it still has a linear-esque curve and IMO too much HS rebound. Also too little HS compression.
                        The TC Kline rear bump is VERY soft while the rebound builds fairly linear it seems (up to 10 ips at least). You get into jacking down by 3 in/sec and the rear is constantly going to be pulling you into the bump stops. Not good.
                        The twin-tube design shows a decent amount of hysteresis - it simply can't be as consistent as a well-tuned monotube, esp. in hotter driving conditions.
                        Most people don't know what to ask a vendor to change - I sure didn't at the beginning of my suspension adventures. There are certain behaviors a damper can produce which - no matter the setting - will result in worse lap times and/or comfort (again, they're more connected than you may realize).
                        Think 'tarmac rally style' suspension tuning more than 'NASCAR style' (rebound-biased). Almost everything out there is the latter, while the superior and provably faster approach is the former (which is how I tune).
                        Shaikh Jalal Ahmad
                        Suspension Decoder @ Fat Cat Motorsports, Inc.
                        Youtube: Suspension Truth
                        FCM E46 M3 Ride Harmonizer spreadsheet
                          OPEN OFFER to the NA M3 forum:
                          As a thank you to Ian for giving me a place to share data and engage in a respectful way, I'll make this offer to bigjae and any other E46 M3 enthusiast. I'll offer a free 30 min free consult to any E46 M3 owner who wants to reach out to me and mentions having seen my offer on this site. I won't be helping plan all details of your build, but we can get into theory and practice, talk ride frequencies and so on. I want to answer any questions or points that may be unclear in terms of my approach to suspension optimization so YOU will be able to make a better buying decision. Not just for your M3, but for anything you decide to modify down the road.
                          If you do decide to do a build then we can do the 30 min paid consult at that time.
                          If for some reason I get 100 people asking for consults I might reduce it to 15 min free, but let's see how it goes. I tend to have 30+ min conversations anyway and I don't charge people for every minute past that. The main point of the consult fee was / is to weed out the time-wasters. I didn't mean it to scare people away from calling to ask questions but the law of unintended consequences applies 😅
                          Shaikh Jalal Ahmad
                            Hi bigjae46 - I remember when you posted some feedback on the old forum when you tried going from a pitch-based spring rate setup to Flat Ride. IIRC, you like it. Your comments here reflect that again and I'm glad to hear it!
                            The TC Klines are weak in compression and strong in rebound as is the case with nearly every twin-tube I've come across, and quite a lot of monotubes as well. This results in a propensity to jack down and bottom out.
                            You don't NEED to go with the Stage 3 Ultimate - in fact, I'd almost rather you DIDN'T because it seems people get scared off by the $4400 price tag (I get it, it's a lot of money) and the Stage 2 @ $2400 gives you a LOT of value for the money. I still calculate max bump force to avoid launching the car up in the car, and I adjust max rebound force to avoid high speed jacking down.
                            To be very honest, by going to Flat Ride and making whatever bar / aero / alignments adjustments you need likely solved 70% of your overall problems. Your results reflect that improvement. One of the 'magical' things about Flat Ride with the higher rear wheel rate / ride frequency is that the your car WANTS to rotate through the turn (instead of the front dragging the rear when you have pitch).
                            Another magical thing with Flat Ride (my 'first principle of Ride Harmony') is that (shhhh) the dampers have to do much less work compared to a pitch-based setup! And if you get very clever, once you have Flat Ride if you have a clever shock builder you can do cool things like design anti-bottoming / internal bump stop behavior (sorta like a rally car but I keep saying that don't I...??). This really isn't possible when the front and rear are pitching and fighting each other. It's a miracle to get through the turn without sawing at the wheel like you're driving a damn gokart.
                            Mind you, if you had pitch, you'd have to run more rebound - that's what I had to do in the beginning when I was designing race setups. Everyone used higher front frequencies and that means a lot more rebound to control everything. If you don't force the front to be unnaturally higher frequencies than the rear then the car has a faster settling response via Flat Ride, and the dampers have to do a LOT less work. That also means better longevity, and it makes the dual-duty of street driving an FCM Elite much more pleasant. You only need to tweak tire pressures for the track and you're good to go.
                            So let's talk - and I think if you aimed for an FCM Elite Stage 2 you will find it exceptionally capable. You'll really be able to feel the difference that a superior damping approach can make.
                            I would invite anyone reading who doesn't know what I mean by Flat Ride to watch my 'What is Flat Ride and Why Should You Care' video. Then - most importantly - take the time to fully watch the 'Why Flat Ride Matters' video. Looking back, it is THE MOST IMPORTANT experiment I've ever done and has been the focal point that's guided my suspension design approach. The road test was in an Audi A4 Avant using Flat Ride but DEAD DAMPERS (I totally drained the dampers before the shop installed them for a bounce test). I wish I could communicate what a revelation it was to feel that car over a variety of surfaces, including through a slalom (empty industrial roads on Sunday are fun!). It still lives in my memory like my last crazy redhead girlfriend's perfume. Actually, that's faded a bit but I remember how the Avant felt.
                            Shaikh Jalal Ahmad
                              bigjae46 Another comment on your ride frequencies, based on the corner weights and spring rates you provided. You have some mismatch in the side-to-side ride frequencies, looks like around 2.49 / 2.67 Hz front and 2.29 / 2.46 Hz rear. The LF and LR springs should be IMO 50 lb/in and 100 lb/in higher than the corresponding right. Also, I'm not sure if you're on stock sways due to NASA point limitations, but your setup does appear to be pitching right now but perhaps less than before? The damper behavior is likely affecting the overall real-world ride frequency compared to the undamped frequency, and there may be some bump stop contact happening as well. In fact, given the rebound-biased nature of the dampers I'm certain that's another factor to consider as a non-linear behavior you're fighting. I'm guessing that your current damper settings even with D/A are likely still giving a rebound bias though admittedly that's an informed ASSumption on my part.
                              My suggestion would be to separate the front and rear more, something like 425 / 375 front and 800 / 700 rear to get ~2.30 / 2.31 Hz front and 2.45 / 2.46 Hz rear. That'd be about 6% Flat Ride. To keep a similar FRC / handling balance you'd want a slightly bigger front bar, like an Eibach 27mm or just deal with the slightly looser handling with alignment / pressure / other adjustments.
                              If we were going to work together, I'd really want you to get a Ground Control front tubular Race and start with it on a softer setting. It's such a great piece with a HUGE adjustment range and you ought to get some weight off the nose of the car as well.
                              Then, as another change to address the low speed understeer, you'd likely want to reinstall the factory rear bar (or any small bar that fits). Without a rear bar, any car will experience terminal understeer in high steering angle (large weight jacking) maneuvers. This is due to an asymmetry in the roll center migration front vs. rear. The front bar being present limits the dynamic roll center change while on the rear with no bar, the droop is higher and the rear roll center changes more. This acts like a dynamic understeer effect which is what we experience particularly in slower turns with higher steering input / weight jacking. Kudos to Emilio at 949Racing who pointed this out. If you look for some posts by him or anyone else who understand the phenomenon, it makes sense and echoes my prior experience when I used to run Miatas with no rear bar and got terminal low speed understeer. I always recommend any racer run a rear bar - and a good quality adjustable end link to prevent bind & preload.
                              I think the current pitching behavior, the lack of rear bar, rebound bias in the TC Kline, and near-certainty of bump stop interaction and dynamic spring rate changes due to jacking down are all points to address to get further optimization from your tire contact patch. You can make a few changes even with your current TC Kline (and maybe run them even softer than you have them, I don't know what settings they're at currently) and likely get further improvements. But unless the TC Kline design allows you to bias the damper more toward 'rally-style' tuning, especially at high damper velocities, you WILL need a superior damper to get to the next level.
                              I really do think a good front tubular bar will be part of that package. There is something to be said for running as little overall bar as possible, but not when you're dealing with pitch and probably can't get on the power aggressively enough or if the car is still pitching / oscillating back-and-forth, your results are limited. I didn't ask about your LSD type and behavior which also plays a role.
                              It sounds like you've done great to this point - I'd like to see you get even faster. The FCM Elite Stage 2 will be a good choice and also show others on this forum that you don't have to sell a kidney to get an awesome Fat Cat setup.
                              Shaikh Jalal Ahmad
                                Dropping a few links to videos that might be helpful:
                                Index:
                                1. Ryan Upham's E36 M3 experience with MCS 3-way prior to switching to FCM Elite (yes he got Stage 3)
                                2. How Shocks Work - Jacking Down (Rebound vs. Compression)
                                3. What is Flat Ride?
                                4. Why Flat Ride Matters (the MOST important video I've ever made)
                                Shaikh Jalal Ahmad
