Undercoating recommendations needed
    Originally posted by SteelGreyM View Post
    3M Rocker Panel Coating, 08889, Gray, 23 oz Net Wt (650 g) https://www.amazon.com/dp/B000L9VXHE...ing=UTF8&psc=1
    Btw guys I ended up buying this stuff. Matches very closely and looks great. High quality stuff. I can recommend it.
    Originally posted by Jersey_M3 View Post
    It’s not the right color but it appears to be a great product. From Amazon:
    1 of SprayMax, 2K Epoxy Rust-Cure Primer, Gray, Aerosol (1)
    Thanks for the tips everyone!
      Originally posted by Rich022 View Post
      If i recall, the order: seam sealer the welds etc, then self etch primer. I THINK I applied the Light Green 62233, and last the Chip Guard. Reddish has a video on this. I followed their recommendation.
      This has me confused..
      Shouldn't seam sealer be added after the primer? Primer to prevent moisture and rust, seam sealer, then top coat if desired?
      I'm also going back and forth on primer vs something like por15 paint
      🔹 2001 M3 Laguna Seca Blue
      Build thread: link
