Originally posted by Tbonem3
What NON-coilover suspension do you prefer
Good info, thank you. The 20mm/10mmdrop is on the b6s "HD" correct? That is music to my ears as I thought they didn't like any drop at all! Also, their gas pressure seems to lift people's cars, perhaps that's partly where the "b6s don't like any drop" came from.
Another note I fogot to mention is he highly suggested NOT using camber/caster plates with these. It voids the warranty if that causes any problems. I would not advise telling them you have camber plates unless they ask. He said it puts stress on the shaft and cause leaks or other issues.This is my Unbuild Journal and why we need an oil thread
Originally posted by Arith2 View PostThe shocks are designed for 20mm of drop in the front and 10mm in the rear. That's .787" and .393" whereas the springs drop .9" and .6". This will bottom out as previously stated if driven too hard.
I asked bilstein about this too. They repeatedly told me that the shocks cannot raise the car and has no effect on height. Nearly the entire internet seems to disagree but this is coming from the source and makes sense to me. I had B4s before which are not high pressure and now B6 shocks. To my eye, the car sits exactly the same.
The Bilstein shocks have a reputation for not working well with lowered cars because they have less bump travel than any other shock I can think of sold for the car. The are low on bump travel with stock springs. Lower the car and you may be sitting on the bump stop by default.
Originally posted by yhp2009 View Post
Are there coilover conversion kits compatible with the B12? Perhaps we can simply adjust for that difference in drop?
I don't know why anyone thinks shocks will raise the car. They control movement, not push the car up. You what controls ride height? Springs do it. This is a stupid rumor from people who don't understand basic undercar theory. You don't put ride height adjusters on shocks, you put then on the springs, always. Don't believe everything you read on the internet.This is my Unbuild Journal and why we need an oil thread
Originally posted by Arith2 View PostAnother note I fogot to mention is he highly suggested NOT using camber/caster plates with these. It voids the warranty if that causes any problems. I would not advise telling them you have camber plates unless they ask. He said it puts stress on the shaft and cause leaks or other issues.
These camber plates are built at an angle, just like the engineers correctly determined the stock ones should be.......A straight camber plate will always hold the strut at angle, causing premature wear of the side seals, especially on Bilstein PSS9. This is because the e46 M3 strut NEVER is straight.Ground Control Sport Camber / Caster Plates This a high quality, complete replacement for the e46 upper mount, this product is not the style that is bolted between and raises the car. This is a camber plate for the E46 M3 (for non-M E46 click here). Camber is adjustable through a 2 degree range.Stainless steel reinfor'03.5 M3 SMG Coupe - Jet Black / Black
The B12 is a kit with B6s shocks and the Eibach Pro Sport kit so no. It isn't a coilover kit. I'm not entirely sure what you mean by your question but I can't imagine any interchangability possible.
So to be sure, as all things in engineering land, without data, is all speculation or opinions. Anyone with side to side dimensions of Bilstein VS OE, or other brands, please share.Last edited by maupineda; 10-07-2020, 03:33 PM.
I believe I read about the gas pressure raising the car slightly from EricSMG and Dal back on m3f, both respected guys, especially Eric with regards to suspension/chassis.
IIRC, Dal even went so far as to make a .gif showing the effect of the bilstein b6 pressureDD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
Originally posted by Tbonem3 View PostI believe I read about the gas pressure raising the car slightly from EricSMG and Dal back on m3f, both respected guys, especially Eric with regards to suspension/chassis.
You can compress the shock by hand, how would that affect ride height. They have high pressure in a specific place to do a specific job. The gas is not supporting the shock.
This is exactly how air suspensions work and why those air suspensions can lower and raise the car by just adding/removing air pressure from the chamber, in the case of shocks is not compressed air, but nitrogen, but is the same physical phenomena
I think a good analogy is a bench press scenario. You are the spring, the car is the barbell and weights, and the shock is the spotter
If youve ever bench pressed with a spotter you'd know that the slightest upward pressure makes a huge difference. It can actually result in the spring coming to rest at a less compressed stateLast edited by yhp2009; 10-07-2020, 05:48 PM.
Originally posted by yhp2009 View PostI think a good analogy is a bench press scenario. You are the spring, the car is the barbell and weights, and the shock is the spotter
The only difference on the shock is there is a valve instead of a marble that allows oil to move back and forth between chambers. The oil is under pressure but a valve allows oil to flow freely (at some rate) between chambers. There is no higher pressure on one side of a valve vs the other until the shock is rapidly compressed or extended.
Hmm I see what youre saying. Ive always understood it using my bench press analogy.
The solution in my mind is that at any point along the compression of the B6 shock, it will take more force to press it further compared to an oem shock. And then it follows that the spring will reach "equilibrium" at a higher position.
But Im not an expert on this so just take it as my 2c
