e46 M3 Tire Sizing Thread
    Originally posted by narudnad View Post
    I can’t remember if the perch is or isn’t atm. I have ohlins on right now. 265/35 was my plan.
    I have the option to go with 18x10 +25, there just not in my preferred color.
    I have ohlins with 9.5et22 and they will clear the strut no problem. I run a 10mm spacer in the rear to make it look a bit more balanced with the front.
      Tbonem3 Thoglan you guys rock, thanks for insight and clarification!!
        Can you share the size tire you opted for where you didn’t have any clearance issues? Thanks!
          I'm not a good example because when I ordered my PS4S's 265/35 was not available. I went with 255/40 and have clearance issues as a result of the additional height of the sidewall. 265/35 will fit fine, someone on here will be running that exact setup as it's quite common.
            Great thread. I'm wanting to go 235/265 on comp wheels but the rears are limiting my tire choices. Might force me to 245/275.
            Interlagos 06 M3, Autologic tune, Agency Power midpipes/exhaust, Fortune Auto coilovers, UUC SSK, Bluebus, Lightwerkz retrofit. MRegistry listing here
              im having super decision paralysis. Stock m3 and i just ordered the ZCP wheels with the 8" front and 9.5" rear. I'm reading 235/35/19 and 265/30/19 are the way to go here? My rig is mostly street driven and may see occasional use. I really want to avoid any rubbing on the front or on the rear. I just want it to fit and not worry about rubbing and im not too crazily concerned about understeer. Most I ever do these days is carve canyons. Maaaaaybe an occasional track day. Will this size just work? Thinking about indy 500s
              edit: nvm, I think I answered my own question. The tire widths on Tire rack are extremely helpful in figuring this out
                BMW M seemed to think 225/40/19 and 255/35/19 are a good fit... 🙄
                2003 Imola Red M3 w/ SMG
                  That size will work. The factory wheels (including OEM ZCP) have plenty of clearance. Bumping up your tire widths by 10mm per corner isn't going to cause any issues. I am on stock 18" style 67's (8 and 9" widths) with 235/40 and 265/35 PS4S.
                    Question - are 8 year old Conti ECS DWSs worth anything? Stock ZCP sizes 225/40 255/35. Old but only 17K miles on them and they look in great shape, car always garaged and rarely driven in winter. Not sure about discarding after getting new tires or keeping and selling.
                      Why not just use them?
                      Hard to say they have value when there's risk associated with using 8 year old tires. Maybe list all 4 for $100 local pick up?
                        Would be ok for a drifter probably, but I wouldn’t use them for anything else, or try to sell them to someone who would use them.
                          Hey all-
                          Has anyone run 275/40R18; all around, on E46 M3?
                          Offset will be standard setup for squared wheels - ET35 with spacers in the rear.
                          I did run 275/40R18 in the rear at one point and found them to be a tad too tall but never done them up front.
                            Chiming in with my wheel and tire setup since I didn't see it under the recommended section.
                            BBS LM
                            19x9
                            19x10
                            ET27 all around
                            PS4S 245/35/19
                            Cup2 265/35/19
                            Love the meaty look of this setup, definitely rides a lot better than my former stock 225/255 19's setup. Also got to shake it down on the track this past weekend and the car performed flawlessly.
                            Future plans include raising the rear up a tad as the cup 2's rub every so often just barely. My goal was functional aesthetics which I think I accomplished quite well.
                              Looking for some recommendations on tire sizing on a stock car and stock 19” wheels.
                              I’d rather use a slightly wider tire in front then 225 so am thinking of getting continental ECS2 tires in 245/35-19 & 275/30-19. Does anyone have experience running this tire at those sizes on a stock car? Unlikely I’d ever lower the car very much.
                                Those will fit. For a stock car, I'd probably just stick with the stock tire size. Modern tires are already very grippy compared to the PS1/2s the car came with. CSL used a 235/265 if you want more tire for a stock car. The ECS1 in the 235/265 has plenty of grip for the street.
                                Edit: Another reason to keep the stock tires is the extra sidewall, tire profile - 40/35 vs 35/30 - for a little more ride comfort.
