Originally posted by heinzboehmer
Need help diagnosing problem after vanos update
Originally posted by eacmen View PostI don't agree with everything these guys do but it's a good visual aid alongside the Beisan procedures.
As the start of this video, the hub bolts are finger tight, crank is at tdc, and cams are aligned using the bridge.
Don't know if anyone watched the video in the first link I shared from Google Photos that shows the exhaust timing constantly bouncing around between approximately 19 degrees and 8 degrees. Does that give any insight into the problem as opposed to staying more constant? I didn't know if it could actually bounce around that much that quickly or that could possibly be in error.
Originally posted by boadly View Post
Like I said I can't move either cam more than a few millimeters with the hub bolts tightened even with the solenoid off. So with the crank locked at top dead center and the hub bolts loosened I would rotate the cams so they would perfectly align with my BMW timing tool. I then tightened the hub bolts and reinstalled the Vanos making sure the camshafts didn't move. After that, I rotated the crank multiple turns, locked the crank and checked the timing again. At that point I may have had to rotate the cams a millimeter or two to get the pins on the timing tool to slide in perfectly.
Originally posted by boadly View PostYes, when I opened it back up you could see the timing was off.
"So with the crank locked at top dead center and the hub bolts loosened I would rotate the cams so they would perfectly align with my BMW timing tool. I then tightened the hub bolts and reinstalled the Vanos"
It's wrong to bolt up the hub before install the VANOS. Read up the instruction and ask question if needed.
Originally posted by sapote View Post"So with the crank locked at top dead center and the hub bolts loosened I would rotate the cams so they would perfectly align with my BMW timing tool. I then tightened the hub bolts and reinstalled the Vanos"
Originally posted by sapote View PostIt's impossible to have the EX cam too advanced at idle if everything was bolted down and the cams were verified with the timing bridge tool with crank at TDC. However, It's possible for ex to be error with too much retarded. Are you sure EX is too advanced and not retarded?
I'm not sure of anything at this point, lol. You can see the numbers from the tests I posted.
At idle EX timing should be 0 degree which is the max advance. Therefore anything not zero is retarded timing. If you're having EX too retarded at idle then it is understandable -- mostly due to wrong timing setup. When the engine turned off, the EX should be resting at max advanced, which means you can verify this by seeing the VANOS piston at its most reward position (to push the spline shape deep into the hub). So just open the VANOS piston cap and see the piston position.
It’s 19 crank degrees retarded instead of zero, which means if the EX cam is marked for reference after engine turned off, then open the piston cap and solenoid plate removed, try to advance the EX cam with 24mm wrench while pushing in the piston, the cam should advance 19/2=8.5 cam degrees to its max position. If this is confirmed then we know what’s wrong.
Originally posted by sapote View PostIt’s 19 crank degrees retarded instead of zero, which means if the EX cam is marked for reference after engine turned off, then open the piston cap and solenoid plate removed, try to advance the EX cam with 24mm wrench while pushing in the piston, the cam should advance 19/2=8.5 cam degrees to its max position. If this is confirmed then we know what’s wrong.
I took everything apart again and after locking the crankshaft at TDC I was able to get the pin in the timing tool for the intake side. The exhaust side pin wouldn't go in as the cam was rotated too far clockwise.
I then tried to rotate the exhaust cam . It was extremely hard to move in either direction. The exhaust spline shaft was already deep in the hub. Rocking the cam back and forth with a significant amount of force and pushing on the spline shaft I was able to move it slightly further into the hub. I then rocked the cam back and forth to bring the spline shaft all the way back out of the hub. At that point I was able to get the pin in the timing tool.
Again it took a significant amount of force and a significant number of very small rocking motions to finally get the camshaft rotated counter-clockwise to be in time.
The first two photos are with the crank locked at TDC before rotating the exhaust cam. The remaining photos were taken after rotating the cam to be in time.
To recap, regardless of whether I put in my old vanos or old exhaust hub or new vanos and new exhaust hub I still get the same results. Every time I take it apart I get the timing perfect then rotate the crank several turns and recheck the timing. But then when I start it the exhaust cam is off significantly.
I'm pretty much at a loss at this point. The only thing I can think of is that it's electrical. I guess the way the vanos works is the camshaft sensor and crankshaft sensor have to communicate with the ECU and then the vanos so maybe one of those is not communicating correctly.
One other thing and I don't know why it would matter but I did put in new S62 spring washers (or whatever they're called) in the hubs.
Thanks again if anyone has any suggestions.
Originally posted by boadly View PostI then tried to rotate the exhaust cam . It was extremely hard to move in either direction. The exhaust spline shaft was already deep in the hub. Rocking the cam back and forth with a significant amount of force and pushing on the spline shaft I was able to move it slightly further into the hub. I then rocked the cam back and forth to bring the spline shaft all the way back out of the hub. At that point I was able to get the pin in the timing tool.
Q: as you rotated the cam CCW, could you rotate it pass the bridge pin position -- further than where the pin can be inserted in)? If you cannot rotate the cam CCW passed the bridge pin then it means the piston had bottomed on the cap at the pinned position, which is correct.
