Porsche 996 Brembo BBK Conversion Install
    Hassan cut down the metal at the bottom of the inside pad so it wouldn't contact the CM bracket. I run the original, shorter pad, on the inside, and the taller pad on the outside. I swapped the fronts for RR, they're definitely better. haven't bothered with the rears yet.
      Thanks Thoglan. I was buying parts for the project in batches and reading various posts about it. Live and learn. I ended up ordering the rallyroad brackets so I'll see if there are takers for the CM brackets - looks like it works great unless you want to use the larger EURO737 pads
        May eventually do, great intell here thank you.
          For those who are running akebono pads without dampers, do you have the squealing or clunking? I am getting ready to do the mod and have everything expect the dampers. Debating if I should buy them now or do a trial first.
