Hassan cut down the metal at the bottom of the inside pad so it wouldn't contact the CM bracket. I run the original, shorter pad, on the inside, and the taller pad on the outside. I swapped the fronts for RR, they're definitely better. haven't bothered with the rears yet.
Porsche 996 Brembo BBK Conversion Install
May eventually do, great intell here thank you.Interlagos 06 M3, Autologic tune, Agency Power midpipes/exhaust, Fortune Auto coilovers, UUC SSK, Bluebus, Lightwerkz retrofit. MRegistry listing here
